Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Heatmor => Topic started by: heat550 on October 06, 2017, 03:11:07 AM
Title: Heatmor 400 BTU extraction
Post by: heat550 on October 06, 2017, 03:11:07 AM
Has anyone tried just burning slab wood in the outdoor boiler .  I can get 4ft x 3ft x 8ft bundles oak $50
its ruffly 3/4 of a cord per bundle . and I can get them by semi load . my boilers 54 inch deep . so its like
cutting them in half. and stack them in . any thoughts ?? has anyone tried it . is it a trade off of time spent
sawing and splitting . to staking slabs in boiler ? was told there bigger piece also and de barked . going to
look at them next week .  :thumbup:
Heat550
Title: Re: Heatmor 400 BTU extraction
Post by: tinfoilhat2020 on October 25, 2017, 06:11:41 AM
I burned tons of slabwood in my 400 heat....worked great....especially in the fall and early spring. Dead winter I would mix it with splits....but it worked great regardless. I was getting 8ft slabs and all I would do is cut them in half!!
Post by: heat550 on November 27, 2017, 02:46:47 AM
Getting 18 bundles slab oak :) Im committed to them now :) coming after it freezes up  :thumbup:
Heat550
Post by: tinfoilhat2020 on November 27, 2017, 04:29:20 PM
I got 24 full cord of hardwood slab showing up tomorrow got it for a great price couldn't say no
Post by: heat550 on November 27, 2017, 10:19:23 PM
Have you used them before ? I'm concerned how long they will last.
Because there going to burn hot. Hope stove can transfer it in to the water fast enough. I only burned logs before.. :thumbup:
Heat550
Post by: heat550 on December 18, 2017, 02:12:45 AM
Got my slabs ya name for the slabs is Dragon Crack . I put the cap on my chimney extension to slow down the high flyers .
they were hitting 30 feet easy . they burn hot :) thats a understatement dam hot ;)  :thumbup:
Heat550
Post by: tinfoilhat2020 on December 18, 2017, 07:43:17 AM
hahahah, that's awesome. mine have been working out great!!! Mix them with some bigger splits about 50/50 and they work aswesome
Post by: heat550 on December 18, 2017, 10:53:44 PM
Did you turn your thermostat down. I'm getting a 20 degree jump after draft fans shut off . I think it's heating do to coals and steel in fire box is so hot. There is some serious heat in them there oak slabs.. I have boiler set at 150f ..cold stove70f to 140f in about 38 mins. On slabs ..
Heat550
Post by: tinfoilhat2020 on December 19, 2017, 05:07:15 AM
nope i used to have my heatmor set at 175-185. it would overshoot to about 190.
gpt my heatmaster set at 160-180
Post by: heat550 on December 20, 2017, 12:52:46 AM
We're they oak dry slabs ? I might have to check closer.
I'm heating 6600 spft boiler at 150 degrees jumping to
170 degrees on occasion depending on how many slabs I put in.
180 f it be serious over kill but I will try it up to 160 then if it jumps to 180degree I would be pretty safe..
Heat550
quotequoter=d5knapp link=topic=9280.msg80951#msg80951 date=1513685235]
[/quote]
Post by: tinfoilhat2020 on December 20, 2017, 05:45:34 AM
yes oak slabs
Post by: heat550 on December 22, 2017, 04:05:50 AM
Did you notice with slabs if you put in alot to get a good coal bed 4-5 inchs . then about every 5-8 hours give a stir keep putting  in about 3-5 inchs more of slabs . and treat it like coal bed. it doesn't take much to keep it all going  . and heat coming out of ex changers stink hot
cycle times are about 5 mins of draft fan and 30-45 mins off time . Heat coming out is amazing . in reality it kinda the way you fire a indoor stove on a cold night .  but once that grate is covered with coals it really pounds out the heat. and Im only dealing with about
8 inchs of coals over the whole grate . and yes chimney extension cap glows red just before draft fans kick off . Crazy heat .
heat550
yes oak slabs
Post by: heat550 on December 25, 2017, 09:06:26 AM
Yep slabs work good at subzero. It takes more but keeps house warm . Seems 400 is good at the heat extraction.
Heatmor
yes oak slabs
Post by: tinfoilhat2020 on December 25, 2017, 09:58:23 AM
Haha nice Merry xmas
Post by: hondaracer2oo4 on December 25, 2017, 01:21:59 PM
Just to clarify, what is your low and high temps set on the aquastat?
Post by: heat550 on December 31, 2017, 11:01:09 AM
With slabs shut down it creeps up to 15 degrees . so 140f to 160f is set point . But it creeps to 175f burning slabs I'm still tinkering with it at subzero temps outside . Oak slabs it seems to depend on how many coals are in there . more coals the more it creeps at shut down . These are dry bark free oak slabs . went thru about 3.5 bundles so far sence about 2 weeks ago. Very cold weather here . they burn way hotter then I thought they would. At this point I can not totally fill the stove gets to wild . I need to put adjustable duct on draft fans to slow things down .
Heat550
Post by: heat550 on January 05, 2018, 09:46:30 AM
This might give you a idea what burning hot is.
Heat550
Post by: willieG on January 07, 2018, 08:02:27 PM
I hope that isn't that twist together double wall stainless chimney pipe, if it is, it wont take that kind of heat for long
Post by: heat550 on January 08, 2018, 05:30:39 PM
Ok what's going to happen ?  I have fan covers to install tomorrow to slow the air down .
Heat550
survived the polar vortex .
Post by: willieG on January 08, 2018, 06:39:52 PM
maybe they make it better now?, but I had a glass door fire place years ago and I would leave the draft open on cold nights and just let it roar, in early spring when cleaning out the ash one day I notice insulation in the ash, unscrewed the pipes and found the one just as the pipes exited the attic had a hole near the bottom. not sure how long it had been like this but I guess with no insulation between the layers I was lucky I never set the roof on fire!
Post by: heat550 on January 08, 2018, 08:14:59 PM
Oo wow mines on the boiler .. it only does it when stoves going from 70 to 150f on water temp ya long burn . And if I put to big  flat piece of slabs over the grate. And at -20f .needs to be settled down a bit with draft doors on draft fans.
Heat 550
Post by: heat550 on January 12, 2018, 04:10:46 AM
Ok heats going in to water now . had to block off 1/2 of the front draft fan . This means slowed down draft to under grate and above grate . Theres a lot of BTUs to deal with when comes to oak slabs  :thumbup:
no more cherry red rain cap .. so its unbelievable how much everything had to be slowed down .
I would of never guess it had to be slowed down that much . :bag:
Heat550
