All-Purpose OWF Discussions => Plumbing => Topic started by: tinfoilhat2020 on July 10, 2017, 08:14:13 PM
Moving into a new house soon and having to put in a new setup just wondering your guyses opinions I'm going with a plate exchanger or a side arm? Pros and cons of each? Thanks everyone
Sidearms usually have less maintenance and pull less on the boiler because the recovery time is longer.
A plate HX will give you unlimited hot water but require flushing once a year, with the unlimited hot water comes a much larger load on the boiler.
Water that plugs a flat plate can eventually plug a sidearm. At least I've seen plugged up older ones. ? Def takes longer like you said.
We had a job the other day where I doubt there was more than 3 gpm available on the main line coming in. Used two flat plates in series, total of 15" in length. Got approx. 130℉ water out of it on the domestic side with three faucets running. I was surprised, but counter flowing over distance really helps.
It all depends on your water quality if you need to flush a flat plate. Around here with a softened water, most never require flushing.
If you have an older water heater, I would not put a sidearm on it. The sediment in the bottom of the tank can plug it fairly quick.
If you use very little hot water, I would probably go with a sidearm. If you have normal or high volume usage, a plate is going to be better in most cases.
We have a water softener, just installed a new one awhile back, without it according to the Hach test kit I bought we have 37 grains of hardness, with we have less than one grain. Still get rust stains on stuff though if you have a drip. I use a gallon of cleaning vinegar to flush mine, easy enough to do if it was properly installed with the proper valves and only costs a few dollars for the vinegar. I get a little extra cash I’m going to install the rust filter from the same company that makes the softener, very happy with it so far.
Depends on your water. My flat plate's about 10yrs, and never cleaned it. Never run out of hot water when stove runs. Had a side arm before with air locks, sediment ,leaks. Never again.
Thanks guys I'm hearing that a flat plate is the way to go
