All-Purpose OWF Discussions => Plumbing => Topic started by: jamesbodeis on May 06, 2018, 04:57:21 PM
Hey everyone it's been a while since I've been around. Looking for some help with a problem I'm having. I've got a sidearm hooked up to my 40 gallon hot water heater and it has always worked great. Friday a windstorm took our power out and it was off for a little over 24 hours. When the power came back on and everything was up and running I had hot water as usual. This morning my wife wanted to take a shower and the water was ice cold. Stove was up to temp so that wasnt the issue. I felt the pipe coming out of the top of the sidearm that runs into the hot water heater and it was cool to the touch. So I turned the switch on so the elements would come on and we would have hot water again. What would have caused the thermosiphon to stop, and more importantly how do I fix it? Thanks for any help.
Is hot water flowing from the owb to the house?
Maybe the pump air locked or started cavitating when the power came back on?
If the pump is running and the hot boiler water is flowing through the sidearm then it might be airlocked.
If you don't have a bleader valve at the top of the sidearm, open the relief valve to flush any trapped air out. (this is assuming the relief is in a tee at the top of the sidearm)
