Outdoor Furnaces - Manufacturers with NON EPA-Certified Models Only => Empyre => Topic started by: Scott7m on August 20, 2013, 01:26:42 PM
Title: Empyre adds a new line "stainless gasification"
Post by: Scott7m on August 20, 2013, 01:26:42 PM
Empyre has expanded the pro series line up and is now building a 304 stainless gasification boiler.  It is currently available in the Pro 200 and could prove to be the most corrosion resistant gasser on the market.  They are retailing currently for $10,495.  However at this time they are $1000 off, but only for a limited time.
This is something we started asking for 2 years ago and it is finally here!
Title: Re: Empyre adds a new line "stainless gasification"
Post by: yoderheating on August 20, 2013, 08:09:13 PM
 What btu is the 200?
Post by: Scott7m on August 20, 2013, 08:15:41 PM
230,000btu max
Post by: slimjim on August 22, 2013, 07:33:12 AM
Hey Scott, I finally conviced one of the Empire dealers to do the show at Acton Me. with me, he will be burning it right across from me, It's going to be above 90 degrees at the show and between the two of us nitwits we will be dumping about 800,000 btu's all weekend, should be the life of the party don't you think?
Post by: Scott7m on August 22, 2013, 08:12:14 AM
Shewwww weeee
Son where are you going its in the 90's?  We have had very few hot days!  Usually it's a scorcher here all summer but its been high 70's and low 80's mostly.  Last week one day it was like 60 degrees at noon and a one night we got down to 42.
Post by: slimjim on August 26, 2013, 10:45:30 AM
Southern Maine, about 30 minutes from home, finally started to cool off sunday, sold a 250 and a chip burner. Hey Scott the Empyre dealer at the show was having some minor issues with his stove and I told him that you may be able to help, may he call you?
Post by: Scott7m on August 26, 2013, 11:16:04 AM
yea no problem
Post by: slimjim on August 26, 2013, 12:35:35 PM
Thanks Scott I gave him your phone number.
Post by: racnruss on November 29, 2013, 01:34:00 PM
In the whole stainless vs. mild steel discussion,  stainless is said to have less expansion capability.  Is that true?  And if so, wouldn't a gasser have even more extreme temperature swings due to intense gassification temps?
Many buyers fear the cracking of stainless.
Post by: yoderheating on November 29, 2013, 05:36:59 PM
 Are they using 304 stainless Scott? Even so I wouldn't think a gasser would crack unless its low in water.
Post by: ecc_33 on November 29, 2013, 09:05:32 PM
This has my inetrest because my all steel 200 series gasser "sweats"  inside the firebox a bit through out the day. I have seen 153*F to 177* as the highest and lowest ive seen. Im sure thats when there is a big draw on hot water like dish washer and washing machine/ furnace thats when its going so low? I would assume anways that thats the big draw.
Post by: Belknap on November 30, 2013, 05:47:09 AM
It shouldn't be going that low on temp.  When I got my Pro 400 I changed the temp for the blower to come on  from 160 up to 170 and that made a big difference.  I usually don't see my temp below 165 unless I have a problem with a log bridging or something.  Also it seemed to take a week or so before it really got going smoothly.
Post by: Scott7m on November 30, 2013, 06:56:33 AM
you may need an air adjustment, time will tell tho
