Author Topic: shop heat  (Read 27054 times)
NewToIt
  • OWF Brand: Wood Doctor
Re: shop heat
« Reply #15 on: February 27, 2012, 06:22:11 PM »
Here are the pictures... hope they help!  The heating unit is actually hanging about 8 feet off the floor, below a loft and above a smaller shelf.  I keep it at 50-55 degrees all the time, and raise it to 65-70 when I'm out there.  Doesn't take too long to bring up to temp.  I just turned it up when I took these pictures.
« Last Edit: February 27, 2012, 06:29:01 PM by NewToIt »
AirForcePOL
  • OWF Model: G400
Re: shop heat
« Reply #16 on: February 28, 2012, 08:06:52 AM »
Awesome set up! Thanks for taking the time and posting the pics! I agree with RSI, it looks like one of those would be very simple to build and probably be much cheaper.  I can imagine that the squirrel cage blower would move a lot more air too.  Is there any type of filter on it?
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
gmviso
  • OWF Model: CL5036
  • Northeast Indiana
Re: shop heat
« Reply #17 on: February 28, 2012, 08:46:57 AM »
Just replied to your other post with a description and photo of my setup.
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=1867.0
Not going to waste space uploading another copy of the photo.
I know that a typical squirrel cage blower is going to be quieter, however my Dayton fan is noticeable but not objectionably noisy.
Central Boiler CL5036
duke
  • OWF Model: MF5000
Re: shop heat
« Reply #18 on: February 28, 2012, 09:24:28 AM »
Thanks for pics NewToIt, so that set up is pretty quite?, do you have to turn fan on and off or does thermostat do that? I just seen you had switches for on off and fan speed. gmviso thanks for reply to other post,looks like a good setup i'm for sure going with a homemade setup looks like a guy can save a lot of money.
06 Duramax
08 Polaris Ranger XP
MS 310
28 ton Swisher
gmviso
  • OWF Model: CL5036
  • Northeast Indiana
Re: shop heat
« Reply #19 on: February 28, 2012, 09:29:48 AM »
Thanks for the detailed photos NewToIt. Did you make or buy the louvers that you have on the front of your HX? I could not find any and did not want to manufacture them so I just installed mine at the ceiling with about a 10 degree down angle.
NewToIt
Re: shop heat
« Reply #20 on: February 28, 2012, 12:58:07 PM »
The thermostat will turn the blower on and off when the room temp. drops below the set point as long as the switch is in the on position.  I put the on/off switch in the circuit in case I want to keep the blower from coming on at all, as the thermostat does not have an on/off switch.
The louvers came with the unit, and I have not needed to put a filter on it..... as it only operates in the winter when there is very little dust windows/doors closed all the time.
It is nice and quiet, unless on high.  On high speed (which I rarely use), the sound of the air simply passing through the HX so fast will be loud with any blower.  She really pushes the air on high speed.
hddmax66
Re: shop heat
« Reply #21 on: February 28, 2012, 05:15:47 PM »
this was my temp setup. I tried to keep it real simple intill i get the rest of my ceiling finished
NewToIt
Re: shop heat
« Reply #22 on: February 29, 2012, 11:05:28 AM »
That should do it, hddmax!
golffanman
Re: shop heat
« Reply #23 on: July 09, 2013, 10:06:10 AM »
This post is great and has lots of good information in it. I'll be building one of those.
Huskee 22 Ton Splitter
Husqvarna 450 Chainsaw
