Author Topic: i need help to bypass my heat exchanger for the summer  (Read 21729 times)
adamant
    • my pic site
« on: April 27, 2008, 06:20:00 PM »
i think i got it.
cut the IN water line and the OUT water line on the hot water heater (green pex) put tee's in each cut with valves and thats it .right? see pictures below.
i didn't do the install but i am sure i can bypass the h/e in the plenum.
what do you guys think?
i hate to go with the pex fittings because i would have to buy thre crimper. i was thinking about the SharkBite® Push-Fittings.
gas forced hot air/gas hot water
buck supreme insert 2/14/1991 to 2/21 2007 (rip)
LOPI freedom bay insert. (present)
central boiler classic 6048
NEW JERSEY
what we do on the weekends
http://community.webshots.com/user/adamant117
http://adamant.pictiger.com/
RUGERGUNZ
  • Central Boiler 6048
Re: i need help to bypass my heat exchanger for the summer
« Reply #1 on: May 13, 2008, 05:09:53 AM »
Hey
I just had my boiler installed and asked the dealer about adding a bypass.  He installed something I think is even better.
He put a zone valve that runs off the the furnace thermostat.  When the thermostat sends a signal to heat your house it also signals the valve to open to allow the boiler water to flow through the heat exchanger.  When the thermostat sees that the temp is adequate it sends a signal to the furnace fan to stop and also sends a signal to the valve to close and bypass the heat exchanger.
I haven't gotten the install bill yet but I think the valve runs around $150 or less.  I believe it is made by Taco, the same company that made my circulator.
If you are interested in this setup, check out
http://centralboiler.com/Tech/C150.pdf
Hope this helps.
adamant
    • my pic site
« Reply #2 on: May 13, 2008, 07:56:47 PM »
interesting.. thanks for the reply. posts some picts
NEW JERSEY
