Pages: 1 2 [3]
Author Topic: In ground pool heated with Central Boiler 5036... Hot water doesn't keep flowing  (Read 10940 times)
 And of course that is not how I normally do it but if the home owner needs a cheap alternative it is an option.
fireboss
scott I use the pool filter on one side of plate ex and I put a by pass valve in between and that's what I use to control the temp !its a simple as it can get, its all pvc
When the water is flowing through the plate do you notice a big difference in flow back into the pool?
I would keep an eye on the plate. The chemicals in the pool water are very corrosive to the copper in the brazing holding the plate together. If it fails you will want to make sure the water doesn't mix.
fireboss
only when I open the valve all the way I know what you r saying about going threw a 10 plate I keep it open about half way . Its like a mixing valve.
Pages: 1 2 [3]
