Author Topic: Current sensing relays  (Read 7796 times)
R W Ohio
« on: January 23, 2010, 10:36:19 AM »
Does anyone use a current sensing relay to power a lite to show that a pump or a blower fan motor is running,without going out to your outdoor stove? If you do,what brand do you use and what was the cost?
R W Ohio
Canal Fulton,Oh.
rosewood
Re: Current sensing relays
« Reply #1 on: January 31, 2010, 07:34:08 PM »
r.w i. don't have anything like that.but i did have to use 120v sense 24v relay  to control auto humidifier. its a electronic relay model 50 , made by research products.   hope it helps.
mikenc
« Reply #2 on: February 05, 2010, 07:52:53 AM »
RW you may already have something know. I used a 120 volt led light i got from grainger. Cost was aound 10 bucks. Installed so when fan is running light is on. I will try to find part # for you.
Grainger item# 1XWL4 line voltage.
« Last Edit: February 05, 2010, 08:28:15 AM by mikenc »
beeman
  • OWF Brand: homemade
« Reply #3 on: November 23, 2011, 04:51:27 PM »
i liked the ideal so i hooked 1 up the same way if you knead 1 just holler we can work somthing out i have a bunch of them lights gary
R W Ohio
« Reply #4 on: November 23, 2011, 05:59:24 PM »
Thanks beeman, but when I did the install I pulled several extra wires through the conduit from the house to the OWB so I used on of them connected to the output of the aquastat to power the neon lamp on my monitering panel. The only thing is, it shows there is power to the fan motor but does not know if the motor is runing or not. It has worked well so far so I am going to let it alone for now.
RW
R W Ohio
Canal Fulton,Oh.
