Pages: [1] 2 3
Author Topic: Coal vs Wood  (Read 20391 times)
mtoll
Coal vs Wood
« on: February 09, 2014, 02:23:40 PM »
anyone burn coal as opposed to wood ?
Wife Rodeos, have 5 Barrel racing horses
Ride HD Road Glide
Vet  USN / USMC
Re: Coal vs Wood
« Reply #1 on: February 09, 2014, 03:47:23 PM »
We don't grow it up hear in the northeast so not many of us including me would burn it.
Re: Coal vs Wood
« Reply #2 on: February 09, 2014, 04:42:08 PM »
 I've burned my fair share in the past but right now I'm trying out a wood only furnace.
artbaldoni
  • OWF Brand: Nature's Comfort
Re: Coal vs Wood
« Reply #3 on: February 09, 2014, 04:53:52 PM »
On week 3 of the great coal experiment. Seens to work ok if I mix in some wood. Can't get it to run on just coal. Cobbled together a better grate to allow for shaking and more even air flow but still no luck on coal only.
Nature's Comfort  NCB-175
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
Bobcat 7753 w/EEL Tracks
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
sdrockhauler
  • OWF Brand: pand m
  • OWF Model: ml30
Re: Coal vs Wood
« Reply #4 on: February 09, 2014, 07:52:57 PM »
I have been burning lignite coal out of North Dakota all winter and have burned alot of it. It is fairy poor in terms of btu's but it burns well. I just put a couple small pieces of wood in first then put 5- 5 gal buckets of lump coal on top. Gets me 12 to 14 hours. That doesnt seem like alot of time for the amount of coal but like I said it is lignite coal, way different than anthracite or bitumious. And it is also fairy cheap if you pick it up yourself.
mtoll
Re: Coal vs Wood
« Reply #5 on: February 09, 2014, 08:02:27 PM »
Artbaldoni does your NCB 175 have shaker grates. If not would it burn coal better with them. Has the mix of coal and wood extended your burn time given you a hotter fire? I'm not familiar with different grades of coal but could it be the grade of coal that it will not burn.  I'm thinking that mixing both would be a good combination. I'm interested in trying this approach
Ride HD Road Glide
Vet  USN / USMC
mtoll
Re: Coal vs Wood
« Reply #6 on: February 09, 2014, 08:12:33 PM »
Sdrockhuler that interesting. I don't always have wood but live I live in coal country. I have not bought a boiler but I would like a boiler that you can burn wood and coal. I have been comparing boilers that will burn both.
Ride HD Road Glide
Vet  USN / USMC
sdrockhauler
  • OWF Brand: pand m
  • OWF Model: ml30
Re: Coal vs Wood
« Reply #7 on: February 09, 2014, 08:20:58 PM »
mine is a portage and main ml30 with shaker grates. Glad I went with the shaker grates.I am on the second year and this year has been a real test with as cold as its been here in SD. Was originally not going to get the shakers but its not much more money. I haul gravel and asphault and was close to coal so I bought a whole truckload and am glad I did. alot easier than cutting wood and a whole load (16 ton) costs under 500 bucks. Takes awile to get used to burning it as I didnt know anything about coal...
artbaldoni
Re: Coal vs Wood
« Reply #8 on: February 10, 2014, 08:21:48 AM »
@mtoll
When I can keep a fire it cuts wood consumption by 50% or better. Trouble is keeping it fired.
No shaker but the grate I fabbed can be shaken to remove ash. At 2100 yesterday with a mix of wood and coal I had a beautiful fire, blue flames dancing,etc. Went out this AM and cold as ice, ok not really that cold but no fire.
I think the issue is that the idle time allows the fire to actually go out. I tried propping the damper flap open (when the blower shuts off) with a stick yesterday but it gave me and overfire condition - 200+°. That was with a pencil sized (1/2") opening on the flap. Got some 3/16" and 1/8" keystock to use for shims to try to dial the "constant draft" to just keep the fire going but no overfire. I will figure this out!
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
mtoll
Re: Coal vs Wood
« Reply #9 on: February 10, 2014, 09:37:45 AM »
Good luck Im pretty sure ill not get my unit in and up and running yet this winter but if I do it will be with a mix of wood and coal or just coal. Im pretty sure you would need shaker grates to make it work with only coal.
Ride HD Road Glide
Vet  USN / USMC
Re: Coal vs Wood
« Reply #10 on: February 10, 2014, 09:45:51 PM »
Types of coal got me curious so I looked it up,  http://www.worldcoal.org/coal/what-is-coal/
artbaldoni
Re: Coal vs Wood
« Reply #11 on: February 11, 2014, 06:45:08 AM »
Mix of wood and coal still burning overnignt! Could it be I have this figured out?
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
mtoll
Re: Coal vs Wood
« Reply #12 on: February 11, 2014, 06:52:07 AM »
Way to go you have to share with us your combination of wood and coal
Ride HD Road Glide
Vet  USN / USMC
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: Coal vs Wood
« Reply #13 on: February 11, 2014, 07:17:29 AM »
What do you have your temperature differential set at?  The conventional wisdom on here, even with a mixture of wood, is a 5 degree swing or somewhere thereabouts.  The tighter swing keeps your coal burning.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
artbaldoni
Re: Coal vs Wood
« Reply #14 on: February 11, 2014, 07:25:40 AM »
Diff is set at lowest possible 5° on the original Honeywell aquastat.
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
Pages: [1] 2 3
