Author Topic: water pump on stove  (Read 4277 times)
horse62049
water pump on stove
« on: September 15, 2010, 06:27:13 PM »
Is it better to have your water pump run all the time or cycle on and off with the thermostat. And do you think you would burn more wood with the pump running all the time.
Re: water pump on stove
« Reply #1 on: September 15, 2010, 06:37:29 PM »
my vote...always on
always hot water when needed..no waiting for cooler water to clear the lines
lets see what everyone else says
Larson88
« Reply #2 on: September 15, 2010, 07:11:45 PM »
mine runs steady
Dirtslinger
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #3 on: September 16, 2010, 01:58:03 PM »
mine pumps 24/7
Dirtslinger
Brockway, PA
  • OWF Brand: Aqua-Therm
  • OWF Model: S-275
« Reply #4 on: September 16, 2010, 07:40:02 PM »
Taco 007 pump..runs 24/7 on mine
horse62049
« Reply #5 on: September 17, 2010, 10:18:07 PM »
thanks guys mine runs all the time also it seems this is the way to do it.
gandgracing
« Reply #6 on: September 27, 2010, 02:43:21 PM »
Yeah mine runs all the time too.  Didn't like the cold air when furnace kicked.
jackel440
« Reply #7 on: September 27, 2010, 03:09:34 PM »
mine will be running all the time also :thumbup:
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
arkgac5
« Reply #8 on: October 08, 2010, 12:17:25 PM »
My water pump turns on when wall thermostat calls for heat. Set up via relay. When I installed outdoor boiler, I too was concerned anout cold air from water pump lag time, but reality is, convection currents always keeps warm water in the heat exchanger. My unit never blows cold air, even if thermostat hasn't called for heat in a while.
I think many are set up to run continuous when hot water heat exchanger is on the same line as the furnace heat exchanger. My heat exchangers are on seperate lines / pumps.
Either way works fine.
Jerry
2007 Shaver 165
Near Harrison, AR
« Reply #9 on: October 08, 2010, 01:12:03 PM »
Another reason to run the pump all the time is that it helps mix the water in the furnace and helps keep the water in the top of the water jacket from boiling as easily on hot days.
jackel440
« Reply #10 on: October 08, 2010, 03:23:27 PM »
I agree. I also have heard of problems with the pump not running all the time,and then the impeller siezing up.Probably due to hard water or junk in the water.
New Holland LS170
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
