Author Topic: When do i know my circulating pump needs to be replaced  (Read 1719 times)
RJ1968
  • OWF Brand: Shaver
  • OWF Model: Not Sure of Model #, it is a front loader with ash door
« on: December 11, 2014, 07:35:20 PM »
2nd season with my Shaver furnace, everything has been going great until tonight.  My circulating pump on my furnace quit working, it was working this morning but when i got home it was off & steam was coming out of the overflow tube on the side of the furnace(i could hear the water bubbling).  The unit is approx 5 years old, but i have heard pumps should last pretty long, could the water getting too hot have an impact on the circulating pump working?
Thanks in advance for any advice..
RJ1968
  • OWF Brand: Shaver
Re: When do i know my circulating pump needs to be replaced
« Reply #1 on: December 11, 2014, 08:42:58 PM »
i think i might of found the problem, my damper door was slightly cracked open..  too much air probably got in & caused the rise in temp(as i have never had this issue before)..  pump is still too hot, waiting till the morning to see if it will cool off & start working again..
CountryBoyJohn
  • OWF Model: MF 10,000 E
« Reply #2 on: December 12, 2014, 05:40:07 AM »
Yes, steam is hard on your pumps.  I had a boil over a few weeks ago and I had one of my pumps not running when I arrived and the other was making some terrible noises!  But, after getting the water temp back down, both of them fired back up.  Good luck!
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
« Reply #3 on: December 12, 2014, 06:22:04 AM »
Luckily never had to deal with a STEAM-OVER, but the two hardest things on pumps is AIR and DIRT.
RJ1968
  • OWF Brand: Shaver
« Reply #4 on: December 12, 2014, 08:20:17 AM »
Thanks for the repy CountryBoy & LJ, pump is still hot to touch this morning & not working..  i was able to turn the screw in the back of the pump so hopefully it is just a matter of it cooling down, will update later today to see if that did the trick..
i did end up ordering a pump today from grainger, it was stainles steel vs cast iron(the one i have now), wont be here for a few days, but hopefully it will just serve as a backup for later...
Thanks again guys..
RJ1968
  • OWF Brand: Shaver
« Reply #5 on: December 12, 2014, 02:35:37 PM »
Well it looks likes it good thing i ordered the new pump, i let the existing pump cool down to touch, restarted it & it does do anything but hum & get hot, i think its fried..  new pump will be here on tuesday i am told..
« Reply #6 on: December 15, 2014, 06:13:30 AM »
You technically only need a Stianless Steel or Bronze pump if your system is open, otherwise you can get away with a Cast Iron pump -> for future reference
Too bad about the pump right before Xmas and all
Coach
« Reply #7 on: March 04, 2015, 07:05:40 PM »
I had a pump go bad on me a year ago.   It started making a whining noise.....just got louder and so I figured I had better replace it.  Does anyone know if these pumps could be rebuilt?  is it worth it?
« Reply #8 on: March 05, 2015, 08:39:04 AM »
In most case NO, not worth rebuilding; Grundfos 15-58 about $85 or Taco 007 about $80, for new off the shelf pumps.  In most cased you just need to replace the pump head or cartridge, not the whole body including the valute
SS & Cast iron are more likely to start around the $150 range MINIMUM, again depending on size.  A Grundfos 26-99 3-speed (seems to be a favorite around these parts), in bronze is around $375, in cast iron its around $260
« Reply #9 on: March 05, 2015, 10:25:23 PM »
Technically yes, in the real world not so much. Had 14 years on a Grundfos 26-99 cast iron pump before switching it out for a Taco Delta T, took it apart and no discernible wear on the housing or volute.
