Pages: 1 ... 4 5 [6]
Author Topic: HELP! I hate my SHAVER!  (Read 470821 times)
PURPLEBOWYER
Re: HELP! I hate my SHAVER!
« Reply #75 on: January 15, 2011, 06:02:51 AM »
Thanks Russ
Windwalker7
« Reply #76 on: January 15, 2011, 08:57:40 PM »
My inner door is warped also.
PURPLEBOWYER
« Reply #77 on: January 20, 2011, 03:12:24 PM »
I wonder if the warpage would have happened even without the blower mod?Doesnt seem to be a problem.This spring when I build my leanto woodshed and incorporate it over my stove Ill have to extend my stack,prob about 4' has anyone just slipped a piece of stove pipe over the existing stack since I have no more wet creasote this shouldnt cause any problems.....right?Probably should have started another thread for this ? cause I dont hate my shaver,but I do need help,at least thats what she says.
« Reply #78 on: January 20, 2011, 04:43:05 PM »
if you extend your stack i am going to guess you will have some creosete and you should extend your stack by slipping a pipe inside your existing stack (with a ring outside to prevent the extension from continuing to slide down farther than you want it too ((or having the exact size welded on))) this way any creosete that does appear will not get out of the chimney and make a mess of your roof or OWB.
i would suggest also insulating if you can.
Russ Brumit
« Reply #79 on: January 21, 2011, 08:49:16 AM »
You can get an adapter from Shaver that slips on over top your pipe and has stops welded in to keep it from sliding down. Thats what i used . I had some triple wall stainless pipe left over from my wood stove and had to get another adapter to use it . It works well and no real creosote drip to worry about. Can get you a pic if needed.
Shaver  Series 290
443-907-7455
