Author Topic: Adding a 16X20 outbuilding to a HE1100  (Read 878 times)
Radio Tech1964
  • OWF Brand: Hawken Energy
  • OWF Model: HE-1100
  • Stihl MS 250 John Deere CS 36 2013
    • Weather Info
« on: February 28, 2016, 11:53:08 PM »
I have a nice prefab building in the back yard that the wife uses for sewing and quilting and I also have my electronics shop in there as well.
We have been trying to heat this with a Monitor heater but the high cost of kerosene has broke me from that habit!
I know my 1100 has a place for an additional pump but would I need an additional pump?  There is less that 100' from the 1100 to the heat exchanger in the house( closer to 50' ) and the lift is near null as well. Could I "tee" into the supply and return lines in the rear of the furnace and use that method to supply the heating system I will fabricate in the building? It is almost down hill and a total of maybe 30 feet from the 1100 to the building.
I really don't see any reason this wouldn't work but sometimes I miss things in the initial survey so it's better to ask those who may have been there previously before getting all my needed supplies on hand.
Thanks for any suggestions on the specifics of this project.
Re: Adding a 16X20 outbuilding to a HE1100
« Reply #1 on: February 29, 2016, 01:58:38 AM »
#1 you will be adding resistance to your flow. #2 return water temps to the boiler will drop drastically.
#3 you will not be able to isolate one building from the other. #4 circs are a cheap part of your system.
             Do it once and do it right, you won't be disappointed with the results!
Radio Tech 1964
« Reply #2 on: February 29, 2016, 11:26:05 PM »
Thanks for the information!
I will look into an additional pump. Connecting to the pump would probably be easier anyway :)
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #3 on: August 23, 2017, 10:04:51 PM »
Did you ever get this building hooked up?
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
