Author Topic: Design for Garage Floor  (Read 798 times)
suzukidad
  • OWF Model: MF5000e
« on: May 17, 2016, 05:47:50 PM »
Building a 30 x 40 garage/workshop and am wanting to put radiant heat in the floor from the Heatmaster. Bought it plenty big for the task but need designs for the plumbing.
Garage will be 2 car brick in construction, 2 x 6 walls, with 6/12 pitch roof with storage trusses. Walls and ceilings will be insulated well.
Any suggestions.
Thanks
Vince
Husqvarna Rancher 455
Husqvarna 440
Jolly Star Sharpener
Suzuki King Quad 750
Polaris Ranger XP700
schoppy
Re: Design for Garage Floor
« Reply #1 on: May 17, 2016, 11:29:00 PM »
The key to in floor radiant is a well insulated floor, both underneath and perimeters. I put up a 50x60x16 and with the help of a couple of friends in the HVAC business we installed the in floor heat. I used 2" high density foam designed to be used under cement. We used 1/2" o2 pex spaced 12" apart with 10 loops averaging 225 to 275 feet in length. They were the experts but I learned a lot and built the manifold system myself. Works great and the best heat source for nice even heat.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
