Author Topic: Timberline carbide cutter. Sharpener  (Read 940 times)
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« on: February 14, 2017, 05:57:51 PM »
I was just wondering if any of you guys have use the timberline carbide cutter chainsaw sharpener?   I went ahead and spend the big bucks to get one instead of using my hand fine and a guide.  Total cost me 200 with the tool, 2 handles and 3 carbide sizes.  I just want to let anybody know looking for a good sharpener that this thing is the Cadillac of hand sharpeners.  I couldn't be more happy with how good this thing works. Usually I can never get a chain to cut as good as when it was brand-new, pretty close but never quite there.  This thing will sharpen a chain as good as new no doubt.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
Re: Timberline carbide cutter. Sharpener
« Reply #1 on: February 14, 2017, 06:00:20 PM »
How long does it take to sharpen a chain?
BIG AL
  • OWF Brand: Heatmaster SS
  • OWF Model: G 200
« Reply #2 on: February 14, 2017, 06:47:40 PM »
It takes me a little less time to sharpen than with a hand file with the Timberline sharpener.I like it for the most part. I have noticed though that if you don't get it perfectly set up , which takes a couple minutes it doesn't work as good as a hand file with a gauge. I also don't think it gets the right angle with some of my chains , and I know they make different angle guides , but still I am going back to a hand file on some of my older chains that have been sharpened a few times.
SE Mass
aarmga
  • Central Wisconsin
« Reply #3 on: February 14, 2017, 09:32:47 PM »
Depends how bad it gets beat up.  5 minutes for a touch up, 10 minutes for a through and through job.
Stihl 211 - 16"
JD 1025r with FEL
aarmga
  • Central Wisconsin
« Reply #4 on: February 14, 2017, 09:34:12 PM »
You do know that is why the tool itself can "tip" on the bar some.
Stihl 211 - 16"
JD 1025r with FEL
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
« Reply #5 on: February 14, 2017, 10:21:25 PM »
I love mine. If you use it on an old chain, it takes a few passes to get the teeth the same length. It haven't tried it on a new chain yet but I would have to believe it is better. I got mine from someone that didn't like it. Best $50 I ever spent.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
« Reply #6 on: February 14, 2017, 11:18:08 PM »
Iíve looked real close at em, seems people either love em or hate em. If I didnít already own an Oregon chain grinder Iíd buy one, and before the arguments start, Iíve found if the guy that is grinding the chains is the guy thats buying the chains, they last just as long as if they were sharpened any other way. I also have at least two chains for each saw, so the argument that I can take the Timberline with me is also moot.
aarmga
  • Central Wisconsin
« Reply #7 on: February 15, 2017, 06:30:21 PM »
Now that's a deal!
Stihl 211 - 16"
JD 1025r with FEL
aarmga
  • Central Wisconsin
« Reply #8 on: February 15, 2017, 06:32:52 PM »
I never had a problem with the bench grinder taking too much chain either but it just does not sharpen as good as this thing.  I don't take it with me in the field either.  I always carry 2 chains per saw as well (kind of common sense) I sharpen my chain after every time I cut.  Takes 5 minutes per saw except the 36" bar.  That takes about 15 minutes.
Stihl 211 - 16"
JD 1025r with FEL
