Author Topic: Boiler swap out  (Read 1067 times)
Boiler swap out
« on: April 21, 2017, 05:01:51 AM »
So yesterday we picked up an old Seqouyah Paradise that I sold and are returning it to our shop for some plate replacement, I wanted to post some pics of the process but it seems they won't load again, same I pad and only 2 pics so what gives?
Re: Boiler swap out
« Reply #1 on: April 21, 2017, 06:50:28 AM »
Any ideas Marty?
Re: Boiler swap out
« Reply #2 on: April 21, 2017, 10:03:34 AM »
Sorry, hauled one of the last loads of hay to auction this morning.
Do you get the message uploader full or something similar?
We might be out of space again, jus may have to upload photos to Photobucket, Flickr or even Facebook then copy and paste the link here.
Re: Boiler swap out
« Reply #3 on: April 29, 2017, 04:45:38 AM »
So I'll try again with some pictures of our process
Re: Boiler swap out
« Reply #4 on: April 29, 2017, 04:49:48 AM »
Ok so that worked, here I'll try a few from our rebuild in process
Re: Boiler swap out
« Reply #5 on: April 29, 2017, 04:56:26 AM »
The first one was just under the chimney, this unit has been in operation for almost 10 years and has had a non insulated chimney on it for most of that time. If you look closely you can see the pitting caused by rainwater hitting the side of the smoke pipe and running down into the boiler, Please guys and gals, if you must use extra chimney then use insulated, it is wider and will not allow the water in from the outside!
The next pic is of what we had to remove due to ash and water being left In the boiler.
I sure am glad I have a plasma cutter!
Re: Boiler swap out
« Reply #6 on: July 02, 2017, 10:42:08 AM »
Yep, with the proper tips I find I can go months at a time and never light the gas axe.
