Author Topic: Removing rain cap for cleaning  (Read 712 times)
Radio Tech1964
  • OWF Brand: Hawken Energy
  • OWF Model: HE-1100
  • Stihl MS 250 John Deere CS 36 2013
    • Weather Info
« on: June 30, 2017, 02:11:52 AM »
Has anyone got any good ideas as to how to remove the weather cap for cleaning?
I have tried all sorts of penetrating oils  warm and cold and I can't seem to remove it without destroying it.
I would like to give everything a thorough cleaning at that level since this is the 3rd year of operation.
Thought I would ask here before breaking out the jack hammer and dynamite  :thumbup:
Re: Removing rain cap for cleaning
« Reply #1 on: June 30, 2017, 03:18:17 AM »
if it is already discolored (or you don't mind if it is) perhaps a propane torch? I am thinking it is glued  in with tar from the wood
« Reply #2 on: June 30, 2017, 06:03:14 AM »
What if you burned some cardboard and got it really hot, then the creosote would be soft? Unless it's screwed on..
Install Heatmaster furnaces, dealer support in VA.
High in the Blue Ridge mountains.
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #3 on: July 01, 2017, 02:14:18 PM »
I have the socket type cap which threads on with a half turn.  I have a small gap where the cap threads into the pipe and where the bottom lip starts. I used 2 rubber strap wrenches to turn mine off.  One around the pipe as close to the thread as possible and one in the gap of the cap.  It took a little grunting but it did turn off for me.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
« Reply #4 on: July 07, 2017, 12:37:31 AM »
 :post:
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
Radio Tech1964
    • Weather Info
« Reply #5 on: July 15, 2017, 03:27:47 AM »
Thanks for the Ideas!
Will be shutting down in order to get all serviced and ready for winter and I'll give another shot
Wayne
