I have been thinking about putting together a kit for clothes dryers. The problem is that to order the small size heat exchangers it costs 3-4 times as much for one as it does per unit if I order larger quantities.
If anyone here is interested in doing it let me know and if we can get enough people together for a batch it would be a lot cheaper for everyone.
I have not decided exactly what size heat exchanger would be best but I am thinking around 6x6" or 8x8" should be sufficient.
I know it works with 180 degree water but not sure how good it will for people that run at the lower temperatures. (ie: 140 degrees)
I have had one setup for a couple years but I just used a single row 12x12 heat exchanger with 1/2" pex feeding it. Using the custom size heat exchanger should work out a lot better because dryers suck air in and I don't think it is going through the entire 12x12 area and the extra thickness of the 3 row coil should heat the air a lot better.
Also, I used a second dryer instead of putting it on the main dryer. Mostly for safety since I didn't want to interfere with the heater on the dryer. Also, this allows to dry two loads of laundry if you get behind.
The dryer I put it on I removed the heat source.
You could probably use your main dryer but it would be up to you to make sure it is safe. (I would highly recommend removing the kit and going over the dryer to make sure it is ok after switching it back for the summer if you do this)
I used to have an indoor wood furnace so there was a spot about the right size for the second dryer where it had been.
It looks like heat exchangers would be around $100 each if we can get to the price break quantity. If we can get more together it would drop it more. Also, if doing it the way I will be recommending, you will need a pump also. I can supply that or you could get it on your own. Other parts would probably depend on the specific dryer but a universal kit may be possible.
If there is interest, I would like to see some pictures of the bottom inside and back of different dryers that you have so we could get the best size heat exchanger. If it could be mounted inside it would be a much cleaner looking install.
