Author Topic: Temp guages  (Read 539 times)
Temp guages
« on: December 13, 2017, 04:45:16 PM »
Is there a fitting that could be soldered into the supply and return lines to install a true inline thermometer.
wreckit87
  • Just a stupid pipefitter...
Re: Temp guages
« Reply #1 on: December 13, 2017, 04:56:20 PM »
I use a line size tee with 1/2" branch (for example 1x1x1/2") and a fitting female adapter also known as a female street adapter. Solder the female into the branch of the tee and then screw a thermometer into the adapter. I like the Honeywell GT162 gauges, they employ a brass thermowell that stays in the water stream and a removable thermometer if need be. Very accurate and only $12
F150 Platinum
Silverado 2500HD work beater
Victory Jackpot
Victory Highball
Can-Am Renegade 1000
Bobcat S175 2 speed
Stihl 291
Foley, MN
Re: Temp guages
« Reply #2 on: December 13, 2017, 04:57:20 PM »
In my basement I used regular ole 1” reducing T’s then bought gauges that had a thermal well that sweated in. Find the gauges first, then buy the appropriate T. Stay away from the Honeywell’s. They are all over the place, when I first installed them they claimed I picked 5 degrees up by time it left the basement. I have Miljoco’s on the back of the G200 and they read amazingly close to one another.
Re: Temp guages
« Reply #3 on: December 13, 2017, 05:24:44 PM »
I have all Pasco, but I don't believe them, they have been calibrated. I did take them all out tonight to try and calibrate tomorrow.
wreckit87
Re: Temp guages
« Reply #4 on: December 13, 2017, 05:35:48 PM »
The hell? The ones I use are always nuts on with other gauges. Put a whole stack of em in once for half a job and the other half were Trerice, all read nuts on. Made a believer outta me I guess
F150 Platinum
Victory Jackpot
Victory Highball
Bobcat S175 2 speed
Stihl 291
Foley, MN
Re: Temp guages
« Reply #5 on: December 19, 2017, 09:48:53 PM »
Don’t know man, but like I said, when first installed the water was leaving the basement hotter than it came in according to the gauges, I have like 8 of em just out of curiosity to see what the flat plate pulls, how much the HX in the furnace pulls, the snow melt, etc. None of really agreed with one another unless I just got a bad batch or something.
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
Re: Temp guages
« Reply #6 on: December 19, 2017, 10:58:16 PM »
I'm all uponor pex ...here is a pic on a 1" line ...I use a tee ...thru the 90 deg in so u can get the idea !
