Author Topic: Boiler Pex Lines Redo v2  (Read 880 times)
braveblaster
  • OWF Brand: Ridgewood
  • OWF Model: 7500
« on: February 19, 2018, 04:48:23 PM »
Well, times had come to redo the pex lines from the stove to the house.
I have the original 3 wraps lines shipped with the stove and am losing great amount of heat plus on initial installation I committed the biggest sin, "spliced" (a rookie mistake) underground connections and now I have massive leaks.
With that said, everything is coming out and will be installing new lines this spring. The insulated pex lines I have eyes on are on the link below:
https://www.ebay.com/itm/100-of-TSP-Insulated-Boiler-Pex-Pipe-/302146592099
Anyone with experiences from this store, the sellers and the lines themselves?
juddspaintballs
Re: Boiler Pex Lines Redo v2
« Reply #1 on: February 19, 2018, 05:22:56 PM »
The drain tile is still a problem.  Once water gets in, the insulation inside will absorb the water and you'll have the same situation you have now.  Spend the money on Thermopex, Logstor, Rehau, etc. and only re-do your lines this one time and never have to worry about them again.  Those products have a thick outer shell compared to drain tile piping so they shouldn't allow infiltration ever and the foam inside is closed cell foam that won't absorb water if it does.
wreckit87
  • OWF Model: C375
  • Just a stupid pipefitter...
« Reply #2 on: February 19, 2018, 05:30:56 PM »
I'm not entirely sure how to say this without sounding like a dick, but you're already doing it a second time because of cheap line. Why would you subject yourself to doing it a third time? My theory is do it once and do it right; there's a reason they call that wrap stuff "do-over line". If you only need 100 feet it's only an extra ~$600 to invest in something like Thermopex or Rehau with a full closed cell foam core. That'll last 100 years and will completely eliminate the possibility of water infiltration.
F150 Platinum
Ugly brown '81 Crown Vic 800 RWHP project
Silverado 2500HD work beater
Victory Jackpot
Victory Highball
Can-Am Renegade 1000
Cushman Truckster 3 wheeler (Steve)
Bobcat S175 2 speed
Stihl 291
Slumlord from hell with a hydronics addiction
Foley, MN
braveblaster
  • OWF Model: 7500
« Reply #3 on: February 19, 2018, 06:07:50 PM »
Thanks guys for the feedback, no offense taken at all. Any links to the sources mentioned?
MD20/20
  • OWF Brand: Nature's Comfort
  • OWF Model: 325G
« Reply #4 on: February 19, 2018, 09:21:09 PM »
I got my Rehau from RSI. He was helpful and did what he said he would.
Central MD
KevinSantelik
  • OWF Model: 6000
« Reply #5 on: February 20, 2018, 05:51:51 AM »
You can also check out freeheat4u.com.
They carry the Reahu but I'm not sure how the shipping to NC would be.
Lowell, Indiana
Ridgewood 6000
Jonsered 2245
wreckit87
  • OWF Model: C375
« Reply #6 on: February 20, 2018, 08:03:17 AM »
Any Central Boiler dealer should carry Thermopex if you have a dealer nearby
F150 Platinum
Victory Jackpot
Victory Highball
Bobcat S175 2 speed
Stihl 291
Foley, MN
braveblaster
  • OWF Model: 7500
« Reply #7 on: February 20, 2018, 05:50:30 PM »
Thanks. I checked them out and right now price is 8.50 per ft plus 349.00 shipping, only option I have so far?
braveblaster
  • OWF Model: 7500
« Reply #8 on: February 20, 2018, 05:53:53 PM »
Closest dealers are a few hours away from me but will call them to see options.
  • OWF Model: G200
« Reply #9 on: February 20, 2018, 07:41:20 PM »
If you are careful burying the pipe in the original post and your ground is fairly dry it should work fine. I would get the platinum 3 or platinum 4 if they still have that though. It is much thicker insulation.
I have dealt with Eastlake a lot but never used their pipe.
« Reply #10 on: February 21, 2018, 04:38:12 AM »
Another thought, along with RSI's suggestion, would be to buy just the insulated pipe (no case) a glue 4" PVC pipe for an outer case. Waterproof and fairly cheap.
Install Heatmaster furnaces, dealer support in VA.
High in the Blue Ridge mountains.
« Reply #11 on: February 21, 2018, 07:33:00 AM »
I had a guy that bought the white casing pipe from Z-supply then slid that inside a solid 6 tile, so basically a double walled pipe and you also gain more dead air space between the 4 and 6.
braveblaster
  • OWF Model: 7500
« Reply #12 on: February 21, 2018, 04:26:56 PM »
Could please expand?
Careful burying as far as the depth?
Thanks!
  • OWF Model: G200
« Reply #13 on: February 21, 2018, 05:41:46 PM »
Quote
Thanks!
Making sure there is no damage before putting in the trench. Filling around pipe with clean sand or powdered dirt and keeping any rocks away from it. If you dig the trench with a backhoe, you don't want to just push the chunks of dirt back in the hole directly only the pipe. The pipe needs to be completely surrounded and not have voids around it for the most strength.
Years ago drain tile made from recycled plastic was used and it broke down over time and leaked. This is one of the reasons that this type insulated pipe got a bad reputation.
braveblaster
  • OWF Model: 7500
« Reply #14 on: February 21, 2018, 06:24:02 PM »
Found this https://eastlakeenergy.com/collections/insulated-boiler-pipe/products/platinum-3
