Author Topic: Pump Going Out??  (Read 226 times)
CountryBoyJohn
  • OWF Model: MF 10,000 E
Pump Going Out??
« on: October 10, 2018, 07:24:02 AM »
Hey guys, I've been running a pair of chinese knockoff Grundfos pumps for now my 5th season.  I had one fail the first year, but it seized up and was obvious it was dead.  This one is starting to sound funny.  I can hear the water in the pump and it almost sounds like air bubbles in the pump.  It sounds turbulent and not smooth.  Is it about to die?  Should I replace it now?  I have a Taco ready to go.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
Re: Pump Going Out??
« Reply #1 on: October 10, 2018, 08:45:26 AM »
I would replace it. If you take it apart I would guess you will find the ceramic bearing is worn down and the rotor is scraping on the side of the housing and wearing through the outer layer.
If that is what is happening with it, it is not likely to make it through the winter.
« Reply #2 on: October 11, 2018, 03:07:56 AM »
Is the actual design of the bearing different than a "name brand" pump? I've wondered but never knew for sure.
Install Heatmaster furnaces, dealer support in VA.
High in the Blue Ridge mountains.
