Author Topic: Temperature settings  (Read 301 times)
schoppy
  • OWF Model: G200
« on: November 27, 2018, 11:16:29 PM »
Hey guys question for you. I have a friend who has a CB gasser. He says he raised his operating water temp settings from 180/160 to 185/170 to help eliminate moisture in his primary combustion chamber.
Have any of you guys done or heard of people doing this on CB or any brand gassers? I get condensation/creosote on the inside of mine especially during light load times. Seems like you'll use more wood if you raise the temps also.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
Roger2561
Re: Temperature settings
« Reply #1 on: November 28, 2018, 06:13:50 PM »
Because I have all baseboard emitters, I run my temps at 190/180.  I want all the heat I can get at the emitters.  I have the new CB Edge 550 that's been warming my house for about a month and I haven't seen a measurable up tick in wood usage at all.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
Kawasaki VN900 Classic LT
New Hampshire
boilerman
« Reply #2 on: November 28, 2018, 09:01:23 PM »
I'm running my new 750 Edge HD at 185 as well and have played with operating at different set points  from 175 up to 190 and notice no difference in wood usage. I agree that higher operation temps reduce creosote buildup in the firebox. My thinking is that a burn cycle brings the water up 10 degrees regardless if from 165-175 or 175-185. The burn cycle seems to take about the same time and the urathane insulation keeps it there until the exchangers in my house/garage pull the water temp down for the next burn cycle.
jreimer
  • OWF Model: Optimizer 250
« Reply #3 on: November 29, 2018, 09:33:25 AM »
I have a P&M 250 and I run it 190/180.  I don't think it really uses any more wood and my theory is that higher temps will reduce the amount of oxygen in my water and anything to keep the chambers drier is a good thing.
The only drawback I have noticed is increased evaporation.  I need to top it up a few more times a winter.
Shindaiwa 488
GMC Duramax 2500HD
Homemade splitter
Kubota B7500 w/loader
An understanding wife
schoppy
  • OWF Model: G200
« Reply #4 on: November 29, 2018, 08:04:17 PM »
Appreciate the responses. How about any Heatmaster gasser owners, have any of you guys tried higher operating temps and if so why and what results have you seen?
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
« Reply #5 on: November 29, 2018, 08:31:43 PM »
Running 170/190 on mine just to keep up with the shop a little better. havenít noticed any real increase in wood consumption. All Logstor for underground line.
  • OWF Model: G200
« Reply #6 on: November 29, 2018, 09:13:50 PM »
Have you ever tripped the high limit? Seems like that is getting pretty close to it.
schoppy
  • OWF Model: G200
« Reply #7 on: December 02, 2018, 07:17:19 PM »
I was just wondering what the high limit is RSI?
Does the higher settings reduce moisture in the primary chamber mlappin (especially in lighter load times)?
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
  • OWF Model: G200
« Reply #8 on: December 02, 2018, 08:15:12 PM »
I think it is 195.
« Reply #9 on: December 03, 2018, 02:04:25 AM »
I've found letting it burn down to a glowing coal bed does wonders for creosote/moisture.
Install Heatmaster furnaces, dealer support in VA.
High in the Blue Ridge mountains.
Pointblank
« Reply #10 on: December 03, 2018, 05:36:14 PM »
I've found this to be true also. Once the wood has burned down, them coals radiate a lot of heat out into the firebox.
Minnesota
schoppy
  • OWF Model: G200
« Reply #11 on: December 03, 2018, 09:58:21 PM »
Ditto on the coals also. I load my G200 twice a day and getting the hang of matching the wood amount to the temperature load is the trick to ending up with that good coal bed every 12 hours or so.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
