All-Purpose OWF Discussions => Plumbing => Topic started by: gmmaxim250 on August 27, 2016, 07:22:36 PM
Hello,
I think my water to water heat exchanger is shot. A lot of mineral buildup on the outside and we seem to run out of hot water from time to time. I am also thinking it might be time to put a new hot water heater in since I don't know how old this one is? I am afraid that the tank has become filled with a bunch of sediment, therefore cutting down on the storage space inside of the tank...any thoughts? I also wonder if the electric hot water heater is the best way to store hot water? Any ideas? Thanks...
If may be able to clean out the heat exchanger. Is is a flat plate type? If so, what size is it? If it is a 10 plate you would be better off just replacing it. If 20 or more it is worth trying to clean.
Electric water heaters are a lot better than gas for storing hot water because they are fully insulated. The bottom and center tube on gas models lose heat.
Electric are a lot worse for sediment buildup though.
No, it is a tube type, might have to replace it, though I am going to try flushing the tank first. Just seems to not be retaining much hot water...could even be pump on furnace, but I will work from hot water tank out.
It is a sidearm?
To find out if it is the boiler pump / loop flow problem, check the boiler water pipe after the heat exchanger. It will be a lot colder than before if it is a flow problem. If you have an electric water heater and hard water you probably have a lot of sediment in the tank. Cleaning or replacing a sidearm may not last a long time if it is.
If the above is true, I would switch to a plate heat exchanger instead. You would have to probably clean it every year if the water is real hard.
Yes, it is sidearm. A couple of days ago, I flushed the hot water heater, and I pulled the the pressure release valve to try and make sure tube wasn't blocked. Since then the temp and longevity of the hot water has been fantastic.
There was probably some air trapped at the top of the sidearm.
