Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Central Boiler => Topic started by: George Scofield on January 11, 2015, 07:03:15 PM
Hey guys, I just hooked up my 6048 for the first time and turned the power on and the dampener opened up and it makes a buzzing sound. Not sure if this is normal as I just bought it used from my neighbor and I'm still green to the owb. Any help is appreciated.
That is normal they do buzz and hum.
lick it ...no chit ...I do it with the fire doors at work = fixed
Yea normal no worries..
They all vibrate or buzz every once in a while. Take the front cover on the door off and spray a little WD40 on the pivot points of the solenoid and damper door. This will help in most cases . My 5036 does this every once in a while. No big deal other than being annoying to listen to.
Its not normal ! Your not making a good connection on the solenoid ,spray the wd 40 where it makes the connection and that will take care of the noise
