Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Natures Comfort => Topic started by: RSI on May 21, 2016, 04:31:41 PM
I put this together on my Nature's Comfort 275G boiler. I made it by modifying two Ranco controllers. The panel on the outside of the boiler is only about 3/4" thick and there is just one small cable and the sensor wire going to it. I just had to drill a hole in the boiler to run the wires through and then screw it to the tin with sheet metal screws.
In the back of the boiler, I disconnected the cable going to the Honeywell and attached the Ranco parts directly to the electrical box. Both sensors fit in the existing well from the aquastat so nothing was needed to change that.
(https://lh3.googleusercontent.com/_eYzHlZ-mI1XSEaU5NijqDrcepotLqzIBKBiAjjY9gDKlpv7npXL1j3XBJ4tDYc9xpsXiY_G5-tY87hGYMhhz-huDbFnSgxjDk2GmNyELeR62HEB9abDKed9eFngAHfOGpwlGaQdkmfMPLs1CS2csQY3AEk-C69RSeQ43BAnNsmqY5o6q7FNkpmINhgdN-P7AQL-l2OQLoYpC2MjPZR4sRNtCtvzlXXfZvqfz_SHB-hbKN9XmksbaC2GgZDMt1mn5qmUJiEYNmGvUnZ_8djek0Iwc_jlGr2ka4vSu2iz3G87mrLvEsYIcQ1rJF7XVXTbeOdsVVCHxbTywwCT4qmEJc99Ck-PFfsqfPQMsekFiriCsYOqoHzzkcXxz_FkYVq1DPjrpNeSvE0TB4utvgFDIBXHR056NlLoHMEYc5eVEbd4kIOjFZxH9P0PrNXisrnUGYkCbBWtQgojQZyN3Us1AuRo8pARuGmaNwXezqaj0gRaCkdDtegVAlRF0qRZFxcrcUroXclkH7rHbyiCGLu-BQ4umqM3KYd8tqEDoVAcGY7gSAGucoN6AmmPNVYj5yIdKJcp6ISml01H0O-DMc35p0PAGBy1VQQ=w1153-h649-no)
(https://lh3.googleusercontent.com/Bl2tQGazaaQnwMVuGyDiYstUhHGtSA5lC1Ge3qYxF9T93-dGfip5eLvmpVxgPYPiZxIfaq4b2jO8mwSfMDe_c_8BfRMZOEnZwmehMlZiet9JZd6vHSwEUf7RqPIUf8whLafl6dMdJkiCA-UCMrYu5u42Iqv0otKbx4obMnOsWz4nU0EyTkdVY7nfSgWDLcXaJqMnYgEuPGmhR22iFxSpTXKR86LNRENaJO3b0LzUosf_UL1_2sFgdBmbfErND8qPHijlpR0vJ7uJCs7s1myks-bSfSbeHW6pJHqMNXB2Z1c1PiYzjBfQGqv-55R_otFtwcxGJhhgNwaVFsx5TsbCvNxW4X9tCmZNAiMQ0SNXmY8__UZYNB8kqmAAe2q4-0rhhtvZVNLchnZMI44YX8Kmy3xA8PetFrED-NgQvYu0nh4dWQHjzjFFZYPLzNbn5zvBQzI4UEglUE-OEchd1Zn2J5Ln3cxMnpRWJXKuz77t5AuYCBYmA-jOYs4TS7Ms67mWojMTjBl8pIMW9iGY131Vh8bG5Iu1YV5JevVTGuXBdo0nTRdn1xHmwFFOSza_sOrYVu5qVklRn4aKy_eL6F94_B1bFKRLKKQ=w1153-h649-no)
(https://lh3.googleusercontent.com/z9nU1L4jv0IiKI3N6WojJy9HPZkdL1u_vAgoLb6p3SgXWcUpAkxqm1DlN9ChCXK-yO6VjudIPZZsg6owdNAyz-BBzWDuzqymcVXAbfa8qc-qWfpiJoqAbVf2JajZgaqsL5jAGRKzafIgo9bYlP8zf5BaU7S4dzEWSF35BBp8LEeOM-Bwi1-RBONsEZH1bNHMMvtPjGpTZkjuH_iy8rQbIBGkt8DlV6oOVDbe5ymhHKuPrAwr5XBxJFT4NfJNJOu57vSHc4HwZnH6I8iBifVyer_2T8-ev6eGM6Oyfevq5kxoMH-GX-32_iFrqMxU2Tc7YuXKj8deNBz9BH2igEdc4ZLJS6x9xpjmVLUTdbmkkRGipNnUnwjFc8QIHl1tHWinFJN19l96mnG7QiGuXW7eMkv3awHjwl5RQTgYql-Zs1vC4w5Q2zRMj8934BB9XyoyICLTPhD0sDhGLZKwA8IJT9plQBPVkLenZ9WNHSZIaNifg0G0IgYGtAioi-C7HznQaAwX5rJwJilJhNLTBuvvBPvcbXgvvBY2uUxVPnn10aPqqFlLXalWIO0IgwhnI20teezazYI-x3UL2mAuReMmVih7bQ4u86Q=w366-h649-no)
Do you have part numbers on Ranco controller. Have a 325 and thinking about doing the same thing but with a snap switch.
It started out as the same controller as Nature's Comfort uses on the GT6000 boilers.
Hey RSI do u still have an NC or both?
The NCB-275G was sold. I only am burning a Heatmaster now. I have a couple Nature's Comforts on the lot though.
What the name of your business. (If u dont mine me asking) I'd love to come take a look at the heatmaster line.
RSI Boilers
Only currently have a G400 in stock. Should have the others sometime soon but haven't heard when they will ship. I do have the G200 at home that is running that I could show you.
