All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: victor6deep on February 28, 2013, 05:24:31 PM
http://eastlakealternativeenergy.com/water-pumps-for-wood-boilers/ (http://eastlakealternativeenergy.com/water-pumps-for-wood-boilers/)
Am I the only badass that has one of these bad boys or what? Don't be afraid to say " Yah, I have one".
I've got a whole box full of ones that failed, does that count? lol
I am still on my original pump and when it dies I will let you know.
The pump on that same page right below the broeder is a dandy.. Uses well under half the electric as the broeder and has higher performance.
That broeder uses 285 watts on high, 245 on medium
The Armstrong is 115 watts
Once the broder pukes I am getting the E9.
Ayuh,... It looks Exactly like the Grundfos pumps I'm runnin', with a different color paint job...
The only 1 that's sorta gone bad on me, was tryin' to pump steam...
Once the problem was fixed, 'n the boiler refilled, it's still out there, pumpin' along...
It looks similar because it is a knockoff of a Grundfos. If you put the two side by side they don't.
Grundfos is one of the best brands which is why it gets copied the most.
I have a broeder on my GT-220 Natures Comfort. It been running for three seansons now.
I don't know what to say about these pumps yet but it is a pumping bitch I gotta say. I run mine on high and usually bleed it out once a month just because I am kinda ocd. I bought a spare cartridge for 22 bucks. So far so good.
I have a broeder its 19.60 a month just to run the pump im gonna change it to a grundfos alpha
.ITs only three months old but costs wayyyy to much to run.
How much pipe do you have total round trip and how many heat exchangers? The Alpha might not be big enough.
Around 110 feet and prob six feet at highest point a 18x16 heat exhcanger and a 10 plate for hw
and a 80k tube exchanger for hot tub with 8 90's
That 10 plate is gonna hurt ya. There pretty restrictive.
Really ? should of done twenty? I have my set up heating water as it goes into water tank so there is always plenty
Is the alpha not quite big enough? or is there another pump thats a little stronger just not so power hungry
They just restrict flow especially when trying to get by with smaller pumps. I think with a 20 plate and running the alpha on high you might be fine, RSI is far better with plumbing numbers than me, but unless the hot tub exchanger is more restrictive than I think and you have 1" pex, it will work I think
You can always sell your 10 plate so it doesn't hurt so bad buying the 20
Yeah, no way an Alpha will work with a 10 plate. A 10 plate is equivalent to adding 270' of 1" pex. At 6 GPM it is about 11' of head pressure loss.
A 20 plate is equivalent to somewhere around 120' of 1" pex and a 30 plate is equivalent to about 45' of 1"
Each elbow is equivalent to about 10' of pex.
So, going with these numbers, you have 110' (assuming round trip) + 270' + 80' (elbows)= 460' and once you add up the rest of the system it is probably close to 500' total. With these numbers I calculate that an Alpha pump will a about 4-1/4 GPM.
If you get an alpha, I would upgrade to a 30 plate or put the 10 plate on a secondary loop and another pump just for it.
Going with a 30 plate would get you 6 GPM with an Alpha. Putting the 10 plate on a secondary loop with another pump would get you a little more than that.
A PL 36 pump should move between 7 and 8 GPM through your current system and draw around 150-160 watts or so.
An Armstrong E9 would do slightly more (almost the same) and possibly use less. They advertise it as typically drawing 115 watts but I never tested one so now sure.
You Broeder is probably doing about 7 gpm. The PL36 would probably gain you around 1/2 gpm or so.
If anyone wants to check my math, send me a PM and I will send all the info I am using to calculate.
Rule of thumb, what should you be pumping per minute through a system to get the best efficiency?
I don't think it is necessarily efficiency, it's carrying enough btu to do the job at hand and still have return temps that aren't hazardous to the boiler. In many instances we see folks who can heat the building with low gpm numbers, but it varies per install. You may be able to get by with 6gpm where someone else might need 10gpm
Armstrong e9 draws 2.0 amps. I am assuming that is a single speed motor which my broeder draws 2.0 amps on high.
You can't just go by amps on a motor. The power factor makes a huge difference on actual watts used.
The more a pump is restricted, the less power it uses. This is because it is under less load.
A PL36 is 2.1 amps but on my system it uses 170 watts and will drop as low as 130 with no flow. If you just went by the amp rating on the plate it would be 252 watts.
Why do people not run strickly 240v pumps?
For what reason would you want to? They are a tiny more efficient but not enough to be worth running the outlet for it.
I used to run one because you can get them cheaper sometimes.
I'd say cutting the load in half is definently worth it. Less heat from the motor also.
To get the best efficiency of what? Most heat transfer or least power usage?
Running at the lowest flow rate possible while still supplying enough heat will be the most efficient.
If you are talking about efficiency as in getting the most heat possible from your heat exchangers then the most possible flow would be what you are looking for.
If you want to really cut down on power usage, you could put a small pump to run 24/7 and a large pump controlled by a strap on aquastat that comes on as soon as you start using heat.
If you need more flow in the boiler to keep it mixed better you could put another small pump there between the extra ports. It could probably just run when the boiler is running. Without having to pump through the whole system, a small pump would circulate more water in the boiler than a large single pump.
It will cut the amps in half but the watt usage will be exactly the same. The motor will put out the same amount of heat too.
The difference in efficiency is probably not easy to measure it is so small.
I am now confused. Ohms law doesn't allow that calculation. A watt is a watt is a watt but if a 2 amp load at 120volt is equivalent to 1 amp load at 240v. There is still a good savings there, plus 240v motors tend to last longer compared to 120v. When we are talking a continuous load that is a pretty respectable savings imo.
If you have two pumps that are the same model and only difference is 120v or 240v, if the 120v pump draws 2 amps, the 240v pump will draw 1 amp. 120 x 2= 240 and 240 x 1 = 240 No power saving what so ever.
The only reason the amp rating really would make a difference is on larger motors where you can use smaller wiring for the same size motor.
Going to return temperature drop is the best way to size the pump. If you are getting too much temperature drop then the pump is too small or there is too much restriction. If it is going back almost as hot when under load as it is arriving at the house then you are just wasting power.
Raising the water temperature will make your heat exchangers put out more heat and give you bigger temperature difference between supply and return.
Well my current setup is working great plenty of heat / hot water.Its only three months going .I am looking for a better pump and keep my broeder for backup.Changing to a 30 plate maybe a couple years down the line.Ill check out those pumps you suggested .Thanks!!
Yes i have 1 inch pex the tube shell exchanger hardly has any flow loss its a 55k not a 80k like i thought.Its a straight through design.
Have you checked how much power the pump is actually using? Those Broeder pumps seem to vary quite a bit.
Some of them last a long time too. I think they are just can't tolerate certain stuff in the water. If your power usage isn't too bad it might be worth just keeping it and see how long it lasts. Then when it/if it dies you can probably just replace the cartridge and get a replacement at that time.
If you don't already have a watt meter, they are only around $20 for a kill-a-watt.
I have a killawatt monitor it shows 240ish at the highest speed really not much change on the middle speed like 218 i think and 180 ish on low and its bearly moving water at the lowest speed.
You must also keep in mind the circulation in the boiler itself! I have actually heard the water boiling in the water jacket due to not enough circulation.
That's true but the pump is only part of that equation. Return/supply placement and overall design are very important as well.
I have the Broeder 39-20 supporting a 500 ft. loop(250ft. each way) of 1inch pex. No 90's and a 80 plate HE. I've spoken with Scott about this and he feels it's insufficient, but when i look at the graphs it seems to fall w/in the parameters. Anyone have any thoughts. Thx.
I feel it's not big enough though because of the big difference in your supply and return temps, have to remember there is a huge heat load on this house as I believe it's over 7200 square feet
Sir, you should've bought the logburner. :bash:
If it is heating the house fine and the only problem is low return temp, I would just put in a mixing loop at the boiler.
Just use the spare port on the boiler for another building (add a tee if it is already used)
Put small pump (15-58 or 007) on it.
For the return, since it is a single point for multiple connections, put a section of 1.25" iron pipe with a tee on it for the existing return and the return from the new pump.
This pump could be connected to a strap on aquastat so it only runs when the house is drawing a lot of heat. I would also either wire it to the blower on the boiler or put in a sensor on the chimney that turns it on. This should circulate much better to give better heat transfer and possibly use a little less wood.
Sounds good to me, definitely a unique and effective approach
