All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: 4CSTRAILS on October 31, 2015, 12:05:02 AM
I have read some posts about the meat thermometer and I did buy one but it seems to work only for a "timed" period. I have to go out to the transmitter to restart it and then watch the receiver for the temp. It shuts off until restarted. To what advantage is this. Or...did I miss something in the owners manual?
What kind is it??
OREGON SCIENTIFIC
I use a redi check. Transmitter in basement receiver up stairs . It works very well. Strap probes with tie wraps to piping under insulation to get best reading.
Are you putting this on the supply line?
Thermo works is your friend !
Ordered a handheld pyrometer from them, very nice piece for the price.
The redirect check I have has two probes. One labeled smoker the other food. I strap one on supply to heat excganger, the other to supply coming out of heat exchanger going to my oil fired boiler. The one that reads wood boiler supply to heat exchanger Iis my main cconcern. I can tell at a glance if I need to add wood.
