Outdoor Furnaces - Manufacturers with NON EPA-Certified Models Only => Wood Doctor => Topic started by: Nick on November 29, 2012, 07:49:59 PM
I recently had to replace the circulator pump on my non-pressurized wood doctor 8000. The pump the stove was installed with was a Grundfos UP26-99 which is no longer available. They crossed it to a Grundfos UPS26-99 3-speed pump. The problem I am having is it doesn’t seem to be producing enough heat to my forced air plenum. Last winter I had all kinds of heat and even cracked the windows all winter long. Now, I can’t seem to get enough heat blowing up thru the floor grates. I measured the temperature at the grate and it is only 26 Celcius therefore causing the blower to run continuosly to bring my home up to a warm temperature. I have tried draining some water from the supply line ahead of the circulator and also removed the coil in the plenum to see if it was plugged. I also tried all 3 speeds on the circulator with same results. The supply side of the coil is very hot to touch but the return is not. This new UPS26-99 circulator has a check valve in it where the original didnt.
It is getting pretty cold these days and any help or suggestions would bve appreciated.
Thank you,
Pull out the check valve and see if that helps. It may be causing some air to get trapped before the pump.
I was told to take out the check valve on mine before installation. I can't remember the reasoning behind that because it's been some time ago, but it has worked fine since day one.
I have the UPS in mine,actually the third one(bad luck with pumps,but that's another story).I don't think I have a check valve in mine and it would serve no purpose to have one.Could your check valve be in backwards?Without seeing your hook-up,I can't see that an airlock could be a problem.
Good luck.
Almost all non-heat problems are from air trapped somewhere in the system.
Sounds like an air block to me. Can you cut into the loop at the lowest point and put in a tee to add water? As suggested I would remove the check valve. Was the new pump installed so the water circulates in the proper direction? Hope it is fixed by now.
