All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: mgw44 on September 06, 2011, 10:21:53 AM
So, the new boiler is being delivered September 16. I had a 65' trench to dig and broke ground three weeks ago. Due to time, rocks, and clay I was only able to dig about 10' in three weeks. So, I rented a really nice Kubota mini-excavator this weekend. Needless to say, I had a great weekend.
I have the trench at about 45" deep which got me down past the clay into nice moist sand.
Now for the questions: At what depth would you recommend I lay the insulated Pex? I see it should be at a minimum of 26" based on my installation manual. Is there a benefit to going deeper? Are there any negatives to going deeper than 26"?
mgw44
The only reason not to go deeper is if you get into ground water. Clay is pretty conductive so if the sand just damp and not really wet then I would try to get it that low. If your trench starts getting water in the bottom (not from rain) then go shallower.
Thank you for the second opinion. The sand is nice. mostly sand and small stones no bigger than a marble. Not a hint of standing water anywhere with very good drainage.
So, I bit the bullet and bought thermopex. CB and my local CB dealer both say 8-12" is deep enough.
When I buried mine 5 years ago, they (CB and CB dealer) said 18", except for under driveway, where I went 24". I think CB still recommends 18"-24".
I Would go below frost line.
Mine is below frost line between 42-48".
I set mine at 40" see pic in the Empyre thread if you would like. the install is complete and now just waiting for cold weather.
When I dug my trench, i did hit water.I put tile in and pea gravel to make sure my pipe stays dry.
iam in north new jersey and i went 48", frost line here is 42" i went over kill on everything !
