Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Portage & Main => Topic started by: Range91 on January 14, 2018, 04:10:16 PM
So I have always been disappointed with the constant smoke out of my chimney while idle so I decided to do something about it. The stock draft stop is pretty piss poor even though it is fool proof it doesn't ever 100% seal. I had a throttle body around and was able to get a good buy on the belimo actuator so decided to remount fan and change it up. The actuator is a tfb120 spring return which I wired up an outlet off my aquastat to plug into. So far it's been working great I see less smoke out my chimney and hope to see less creosote as well. A pic of the setup still have some tweaking to do with actuator mounting. I also want to say that I am very happy with this stove this is the second stove I have had at same location and this thing is superior to the other. I believe they all have there pros and cons but I have been happy with my choice in this stove.
Clever
Do you think the insulation helps, I thought about it but didn't know if it would be good for the pumps to be covered up. That 34-44 is an awesome boiler, I would like to try some coal in mine sometime.
I wouldn’t cover the pumps, they already run hot, no need to make em even more so.
I believe it helps not much for insulation on the back. I have an ecm pump mounted in the house. Originally my 15-58 was out there but I got pissed off when I had to re-plumb back of the stove to draw from the bottom unlike what the manual said. Not a lot of room back there. Used my 15-58 for my secondary loop. I have not tried coal do to the fact I'm getting wood for cheap or free and have no coal source like that.
Excellent idea. That's the worst attribute of an Ultimizer as far as I'm concerned. Now if they'd do that from the factory and add an external thermometer and/or fan switch so a guy doesn't need to open the back door, they'd be top notch
