All-Purpose OWF Discussions => Plumbing => Topic started by: AirForcePOL on January 19, 2012, 02:17:53 PM
When I bought my used Hardy H2 I also bought 85 ft PEX that was two pipes for the heater and 2 pipes for the DHW. 85 ft will get me into my basement but I will need to add about 20ft of pipe to make it to my heat exchanger and my water heater. I am having a hard time finding any fitting that will work with what I have. From what I have found on the internet it sounds like what I have is called PEX-AL-PEX. It is orange and has a layer of aluminum in between two layers of plastic and it says 5/8" on the pipe but the outside diameter is 3/4. Does anyone know if I can connect this type of pipe to normal PEX? And what type of fitting do I need to use if I can? Thank you!!
I have PEX-AL-PEX as well..I don't see why you can't connect reg pex to it..NO different that going from PEX-AL-PEX to straight copper..The part I have is called "Screw pex-al-pex fittings".. www.ardipex.com (http://www.ardipex.com) is where you can find them
If it is 5/8" then you will have a hard time finding fittings. What does the inside diameter measure? Is there a brand name on it? Watts pex-al-pex is a different size than others. If it is older then it is probably Kitek brand.
I can get fittings for 1/2", 3/4", 1" and 1-1/4" but not 5/8"
ok, thanks Matt! RSI, I am not sure on what brand it is. Right now it is stretched out in the yard and inside of corrugated pipe to keep it dry until I insulate it. The inside diameter is about 5/8. I am not sure on the brand. All I remember is that it is made in Canada.
So this is just uninsulated pipe you have? If so, I wouldn't use it. 5/8" Kitek is going to be almost impossible to find fittings for. It wouldn't cost that much to just replace it with 3/4"pex.
You only mentioned the 5/8". Are all 4 pipes that size or are two of them larger?
Also, since this is Kitek pipe, (made in Canada by IPEX) I would check it over real good if you use it. They had a problem with the inside layer de-laminating from the aluminum and bulging inwards blocking off a lot of the water flow.
yes it is uninsulated. I have insulation to put over it but just havent yet. They are all 4 the same size. I will give it a look and check it out. I think it would be easier to just buy new pex at this point. The fittings are a lot easier to find for standard pex than they are for AL-PEX from what I can see.
Are you thinking that the 5/8 won't give me enough water flow?
For the DHW it probably will. It is pretty close to the size of 3/4" pex. It is the fittings that are going to be the problem.
If the boiler lines are only 5/8" then you will probably have a flow problem.
okay, I am just going to go buy some 3/4 pex. Now, I just hope that it will all fit in my 4" corrugated pipe. Do you think it is possible to use 1/2" for DHW? All of my lines in the house are 1/2.
You should really use 1" pex minimum for the boiler and 3/4" for the DHW. Any less and you will regret it later.
ok I will go and pick up some 1" pex tonight. Now here is another question... How would I go about connecting 1" Pex to a heat exchanger that has 1 1/8" OD inlet and outlets?
I prefer soldering fittings on and using crimp or cinch rings. A lot of people just use Sharkbite fittings.
The fittings on your heat exchanger are 1" copper. The OD of 1" pex and 1" copper are 1-1/8"
awesome!!! Thank you for all of your help! Now, I will start the race against time and see if I can get it hooked up this weekend! The heat exchanger just showed up in the mail :thumbup: Thanks again!
