All-Purpose OWF Discussions => Plumbing => Topic started by: NaturallyAspirated on April 11, 2014, 10:36:03 AM
Do they have a US distributor?
:dunno:
Neal
Dunno either, something specific you hunting for
Most accumulator tanks don't seem to have the connections required to tap into the full output of a higher capacity furnace.
Here is what I would like my ideal tank to have:
- 1 1/4"+ connection set to a coil heat exchanger for OWF primary circuit (0-250,000Btu dissipation from OWF to tank).
- 1 1/4"+ connection set to a coil heat exchanger for OWF secondary circuit (251,000-500,000Btu dissipation from OWF to tank).
- 1 1/4"+ connection set to a coil exchanger for geothermal heat pump. Heats the tank in backup mode in the case of no output from the OWF. Sole source of tank chilling for summer cooling use.
- 3/4"+ connection set to a coil exchanger for DHW preheating - for use only when the tank is in heating mode, bypassed when tank is in cooling mode.
- 1 1/4" Top stratification layer connection for water to air heat exchangers.
- 1 1/4"+ Top stratification layer connection for hot tub exchanger and snow/ice melt.
- 1 1/4"+ Bottom stratification layer connection for slab radiant circuits
- 3/4"+ Bottom stratification layer connection for DWH heating circuit
Neal
Why not build one?
Why not build one?
I may have to. :(
Who would you suggest using for the coil exchangers?
Neal
I would not have any idea, how about speaking with a local supply house and see what is available, I would bet that a good solar thermal supplier could help, we have a heavily subsidized company in Maine called Efficiency Maine that sells Marathon tanks for their solar thermal installs, perhaps you could start there.
Something with that many coils will have to be made and open storage in EPDM liner. There are pics of one on hearth. Most I'm aware of commercially available have 3 coils. Look at the http://varmebaronen.com/aqualux-teknik-accumulators/ (http://varmebaronen.com/aqualux-teknik-accumulators/) if you haven't already. Coils get expensive fast and proper sizing if fabricating yourself.
Man Europe seems to be so much more ahead of the game than the US. This sucks. :-\
Neal
Yes they are, in several countries it's illegal to idle wood boilers. And why the big top brands like Viessmann , Kob, Effecta and others are designed for batch burning then shut down. No idle ing, as this is where they are the most inefficient and emit particulate. Everything uses storage, fire it once a day or two and done. Some will calculate how much wood to put in to top off storage, or as in chip or pellet boilers it's all automatic.
