Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => WoodMaster => Topic started by: steely01 on October 18, 2011, 06:29:55 PM
My 4400 water level indicator light is not working. It worked a couple of weeks ago when I was getting the boiler ready for winter. I checked my water level and it is fine, I topped it off when I lit the boiler for the winter this past weekend. This is my 4th winter using my 4400. My temp has not gone above 180 this week. any suggestions?
Welcome steely01, check the bulb first and then make sure the float is not stuck.
Thanks I will!
Mine had the same problem, not the bulb because its an led. This summer when I drained and refilled it worked for a day or two then out again
It was the indicator, ordered a new indicator and replacing it was a snap. Glad it was not the float.
