General => General Discussion => Topic started by: MD20/20 on November 19, 2018, 02:10:06 PM
Title: Fan issue
Post by: MD20/20 on November 19, 2018, 02:10:06 PM
I have my old 325G back up and running. I removed the old 5 wrap and put in 275 feet of Rehau. So far, it seems to have made a big difference.
Only problem since the start up was a threaded pipe leak which caused the blower to get wet and trip the circuit breaker. I replaced it with an old fan I had on hand. It worked fine over night and is now tripping the breaker again. No sign of moisture, but not sure fan didn’t have problems before I installed it. Is there any the solonoid could cause this problem. Just want to be sure before I go buy a new fan tomorrow.
Is anyone else burning a conventional own?
Title: Re: Fan issue
Post by: RSI on November 19, 2018, 04:15:09 PM
Is it the GFCI outlet in the back of the boiler that is tripping?
Post by: MD20/20 on November 19, 2018, 04:36:43 PM
Yes, I think their were known to put cheap GFI outlets, so I replaced it 5 years ago. Maybe should give that a shot again?
Post by: MD20/20 on November 19, 2018, 06:50:17 PM
It’s not the gfi...will change fan tomorrow, and buy a spare solinoid.
Post by: RSI on November 19, 2018, 09:19:50 PM
I would check over the wiring too. Maybe disconnect the wires at the fan and cap them temporarily and make sure the breaker doesn't still trip.
