Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Hawken Energy, support only => Topic started by: Roscoe on January 14, 2016, 02:56:36 PM
Title: Setting Differential HE1100/2100
Post by: Roscoe on January 14, 2016, 02:56:36 PM
Anyone adjust their temperature differential on the HE1100 or HE2100?  I believe the factory setting is 20 degrees. 160 degrees on 180 degrees off. I plan on adjusting mine and I believe its adjusted with a dial inside/under the cover of the Honeywell aquastat. Anyone know? Hawken has yet to call me back with an answer.
Title: Re: Setting Differential HE1100/2100
Post by: woodman on January 15, 2016, 05:28:55 AM
Ya just take the cover off the aqua stat. There is a dial on the side just turn it to the number you want the diff at. 10-30 or anything between.
Post by: Roscoe on January 17, 2016, 01:46:11 PM
Thanks woodman!
