Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Central Boiler => Topic started by: woodisgood on December 01, 2011, 05:15:58 PM
Purchased and E2400 last wk way it sounds it wont ship fron CB till around the 10th. Am starting plate to plate converter and sidearm install tom. Hopefully get the thermopex in the ground pad for burner and wood shed poured nxt wk also.
Welcome to the site. If you run into trouble you have a great group on here to put you back on track!
Hurry up, its gettin' cold out there... :thumbup:
Welcome to the forum, woodisgood.
If your e-classic 2400 is anything like my e-classic 1400, you'll love the thing. Once I understood how to operate it and set the settings for my application (with assistance from the kind folks on this forum) your home will be toasty warm. The outside temp this morning was 20 degrees with a stiff wind and it was toasty warm in my house. So far I've been short cycling it, meaning I service it every 12 hours. All I've ever had to do is make sure the ashes don't get too deep and obstruct the air holes and fill the fire box about half full. For me this approach works best but you'll have to find what works for you.
Good luck with your new purchase and don't hesitate to ask questions. Many knowledgeable people on this forum.
Roger
Welcome to the site woodisgood, I am sure you will enjoy your new toy.
IMO: Any extra work and expense you go to during the Thermopex installation will pay off later.
that Thermopex kicked my butt all over the yard I did it alone, be sure to get help it is like wrestling a bear in wet cloths.
Don't bend too well does it? LOL It must of been harder to bend in this cold weather.
Your efforts will pay off in the long run!!
I'll tell ya tom night how the thermopex goes doin it tom afternoon!
LMAO too funny
My 1400 is up and running I think I might need to up the set point are you guys at 185?
The fire dies at 4 am I got it going then went to work I got home around 6 it was out again so this time I figured out how to set up the idle time I set it to 30 min 20 sec burst, is it winter yet? It is 54 here in ma
johnybcold; I had the same trouble you are experiencing when I first fire up my 1400. It was due to leaving the setting at factory level and trying to operate it with the warmer temps. Here are my settings;
High setpoint: 185 Blower turns off
Low setpoint: 180 Blower turns on
Pulse: 30sec. every 15 minutes. Prevents the coals from dying out.
I have never experienced a fire outage since I set them to these setting. These work for me, you'll have to find what works for you but I haven't experienced any problems with these settings. I know I'll have to revisit the settings and make adjustments as it gets colder. The calender says it's Dec.16th; it was 49 degrees this morning.
I hope this helps.
Roger
Thx I started messing with the settings this morning
