Outdoor Furnaces - Manufacturers with NON EPA-Certified Models Only => Shaver Furnace => Topic started by: tree climber on January 06, 2012, 07:50:06 PM
Title: steam fix
Post by: tree climber on January 06, 2012, 07:50:06 PM
does any body use the steam fix on newer shavers or is it a thing of the past
Title: Re: steam fix
Post by: Treewinder on January 07, 2012, 04:42:30 AM
What is your description of steam fix?
Ed
Post by: tree climber on January 07, 2012, 07:01:25 AM
90 short elbow on overflow
Post by: lugnut on January 08, 2012, 10:53:01 AM
Oh "that" steam fix....had me wondering as well at the first pot.  :-)  I used it up until it all froze over night.  I suppose it would have worked well had I NOT tried turning on the fill valve...long story and not enough coffee here at ho,e.
I did remember seeing another that was made out of many pipe fittings put together and on one side there was a thermometer that would show the actual temperature of the water.
So I suppose you just wanted a "brief" reply....no I do not use it anymore.
Lugnut
Post by: tree climber on January 08, 2012, 12:49:52 PM
thanks for the input lugnut . not realy having alot of water loss from steam. turn on water valve for about 45 sec aweak.think i leave alone
Post by: moocow on January 11, 2012, 07:21:48 AM
Sometimes the cause is that the whole OWB is not level.  Recheck the front to back and side to side level.
Post by: Treewinder on January 11, 2012, 04:16:42 PM
True
Post by: tree climber on January 11, 2012, 04:45:55 PM
IS TURNING ON WATER FOR 45 SEC A WEAK ALOT .HOW LONG DOES EVERY BODY ELSE LEAVE ON
Post by: jimr on January 12, 2012, 07:19:08 AM
mine is sometimes less then 10 seconds. i have a 6in. piece of heater hose with a slight up-turn on it. when i check the water i remove it , turn the valve on and when water starts to come out i shut it off immediately and slip the hose back on. this should be done at your high setting.
