All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: Jack72 on January 29, 2012, 05:25:45 AM
Title: heating crawlspace with water to air exchanger
Post by: Jack72 on January 29, 2012, 05:25:45 AM
Hello Everyone
Has anyone ever tried to heat  their crawlspace with a hanging unit rather than pex under the floor joist??
As long as you were insulated at the end of joist bays and vents real good it may take awhile to warm up but I would think once you had it warmed up to say 90 or 100 degrees it would start to warm floors too?        Just curious if anyone has tried it            Thanks
Title: Re: water to air exchanger
Post by: willieG on January 29, 2012, 05:37:04 AM
may work but you would have to insulate heavily on both the walls and the ground. it would actually be a "hot room" a few grow lights and you would be in business :o
Post by: Scott7m on January 29, 2012, 06:11:06 AM
It would likely cause moisture problems too...
Title: Re: heating crawlspace with water to air exchanger
Post by: Bull on January 29, 2012, 06:39:07 AM
If you insulate the walls and ground good I would not be afraid to try it, oh welcome to the site.
Post by: Jack72 on January 29, 2012, 07:26:33 AM
Thanks for replys
Scott
floor is well protected now from moisture coming up I dont think I would have that issue
Post by: Scott7m on January 29, 2012, 09:36:02 AM
Warm air above the ground will pull up moisture, not sure if it will cause you problems tho
Post by: tawilson1152 on January 29, 2012, 01:56:16 PM
I just fired up my boiler the first of the year and one thing I did with it is put a unit heater I salvaged off a job in the return line to heat my basement, which is about 2/3 crawlspace. If you have cold floors now, which I did, you'll like it. You don't need it that hot either or you'll be roasting yourself upstairs. Now that I have some heat down there I am seeing all the cold air infiltration I had before and am now taking care of that, with Great Stuff, insulation and Reflectix. I have always had moisture problems in warm weather so I've always run a dehumidifier. My house was built on bedrock and the full basement part blasted out so you may have different conditions on a dirt floor. I have spread tarps and plastic out over my crawlspace areas, mainly to make it more pleasant for crawling around.
Post by: muffin on January 30, 2012, 07:27:19 AM
Thanks for replys
Scott
I would be concerned with moisture too.  How is it protected?  Sealing it up will liekly generate a ton of moisture.  I would not be surprised if the floor started dripping, literally.  I know I had a situation with my attic where I had the vents block for a short time during construction and the ceiling litterally rained in there.
