Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => HeatMaster => Topic started by: lasor1 on August 26, 2012, 08:08:39 AM
Is it ok to tee into return line with waterline to fill up stove from inside home use a all valve to shut it off and a check valve to keep it from mixing with drinking water is this possible how do other owners add water to stove thanks!
Thats how I do every one I install. Just put in the check valve and you are fine.
