Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Central Boiler => Topic started by: loneryder on October 13, 2012, 07:35:32 PM
Title: Insulation in side door
Post by: loneryder on October 13, 2012, 07:35:32 PM
I have a piece of 6" insulation covering the pex piping up to the pumps.  I was thinking I should get a bigger piece to cover the pumps also.  But the pumps get pretty hot uncovered so I'm wondering if I should leave them uncovered.  What do you guys do?
Title: Re: Insulation in side door
Post by: johnybcold on October 14, 2012, 02:45:37 PM
I only have throes coveted
Post by: buckgrunt on October 14, 2012, 04:04:48 PM
I have an E-2300 and I am starting my 3rd season.   I have always insulated the pump that is at the boiler with no ill effects thus far.  The illustration in my owner's manaual shows the pump being insulated as well......
Post by: ThatGUY on October 16, 2012, 11:35:43 AM
I saved my self the hassle and put my pumps in the building that they heat and insualted the bejesus out of the PEX pipes coming out the back  :thumbup:
Post by: woodywoodchucker on October 21, 2012, 03:16:33 PM
My pumps are inside as well.
Post by: monty3077 on October 29, 2012, 07:43:07 PM
Is there any disadvantage to insulate the side door? Been running my 6048 for a month now and was thinking about it.
Post by: ThatGUY on October 30, 2012, 09:20:18 AM
There is NEVER a disadvantage to insulating in regards to a radiant system, the more heat you keep - the less wood you burn.  I've actually seen people forget to insulate perimeter of a radiant slab  :bash: and they have some very nice green grass in January and February all the way around the house/garage/whatever
