Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Portage & Main => Topic started by: MrDan27611 on December 03, 2012, 03:42:18 PM
Title: Insulation used on Portage and Main boiler
Post by: MrDan27611 on December 03, 2012, 03:42:18 PM
So I'm installing my new ML42. For reasons not relevant here, I ordered the boiler without insulation or cladding. I honestly didn't think getting insulation would be a big deal. Now that everything is hooked up, it's time to put the insulation on and my insulation guy has run screaming into the woods because he doesn't want his insulation dealing with all the heat.
So what does P&M use for insulation and maybe even more important, what do you guys use for insulation. I'm planning on foam insulation but could use batten if I have to.
Title: Re: Insulation used on Portage and Main boiler
Post by: Trint on December 03, 2012, 04:46:00 PM
I think its about R19 fiberglass, don't think there is anything special about it.  The highest temp the insulation will see is the water temp.  Foam would probably work well and be water proof unlike the fiberglass.  Almost forgot the bottom on mine is only insulated with foam board.
Post by: coolidge on December 03, 2012, 05:31:08 PM
I think the company(PM) uses Roxul for there insulation now. It is rated for 2100 degrees. Good product but only marginally better than fiberglass. NO ITCHING    I have used the roxul product and then sprayed closed cell foam to the Roxul on a CB that burnt.  Wouldnt recommend it.
