All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: InBassAngler on February 03, 2013, 11:08:07 AM
Title: HELP! Has my pump went out or are my lines frozen?
Post by: InBassAngler on February 03, 2013, 11:08:07 AM
So I have been struggling with this for about a week now.  Here's is the story.
I had let my fire go out on the burner cause of warmer temps, but I fired it back up last weekend with the forecast of cold temps.  I got a good fire going and water temps going up as well.  I loaded it up before I went to bed on Sunday night.  Woke up to a cold house and went down to the exchanger to see if the water line was warm, but it was cold.  My though was the fire went out and had a blower issue.  I went out to the burner and saw steam coming out of the overflow tube.  Come to find out, the breaker blew sometime in the middle of night and so the fire kept heating the water to boiling point.  I flipped the breaker back on and added more water to the tank, not knowing how much water was steamed away.
Turned everything back on, but the breaker kept overloading, but for the short time it would run, I had hot water flowing fine.  After some checking, I determined the breaker was bad and switched out the breaker.
Now here comes the problem, I turned everything on and I could feel the pump running and the fan was turning on just fine.  I started a fire and got it going and heating water, but after about 2-3 hours, I had steam coming out of the over flow tube again.
The situation is now, that I have hot water going into the pump and the pump is hot too...now the pipe leading out of the pump is cool to the touch.  I am just assuming when the breaker overloaded the hot water, over heated the pump and seized up.
Now I thought I would take the pump off and verify my assumptions, I was going to drain some water out (drain valve is in basement of house below ground), but didn't have any water come out of it when I opened it up.
So, do I have frozen lines or bad pump or both?  Wasn't sure if any one has seen this?  PLEASE HELP!  I don't want to run the indoor wood stove for the rest of the winter.
Title: Re: HELP! Has my pump went out or are my lines frozen?
Post by: Scott7m on February 03, 2013, 12:31:48 PM
Air locked? frozen?  But where?  What underground pipes do you have?
You may have ran the water level below the pump and now the whole system is full of air
Pump could have Also failed when it got starved for water
Does the pump have a bleeder?  If so crack it and let it blowout, close it, turn the ball valve off on your return, let it build 10 seconds them open it quickly and repeat several times
If it's air, that will usually force it through, "if" your pumps is sized accordingly.
Post by: InBassAngler on February 03, 2013, 12:42:36 PM
I have 1" pex pipe underground.  Grundfos 15-58 pump at the OWB.  I have thought about it being air locked but who ever owned the house before me and installed the OWB didn't install isolation valves for the pump. I think at the end of the day, I am gonna have to take the pump off and see what happened.
Post by: InBassAngler on February 03, 2013, 12:47:38 PM
unless its somewhere in the heat exchange, i havent been able to find one.
Post by: Scott7m on February 03, 2013, 12:51:38 PM
I meant what kinda insulation is underground, just trying to see where it could have frozen if it is, but I doubt it.
There is no valves to close anywhere in the system?
I don't install bleeders but I do isolate the pump, I doubt your 15-58 has a bleeder in the end of the pump as well
You could pull a line off the stove and force water through the system with a garden hose
Supply on top or bottom??
Post by: Scott7m on February 03, 2013, 12:52:15 PM
Doubt you have one, I never install them either..
Post by: Scott7m on February 03, 2013, 12:58:44 PM
Somewhat unusual I think because to fill almost every system there has to be a way to purge the air, but maybe.....
Nahh... I never have had an issue, I sometimes install isolator flanges with a water hose connection on them to use a water hose to push any air out, but thats rare
Post by: Scott7m on February 03, 2013, 12:59:54 PM
If his supply is on top, he's sucked it full of air and now the system is air locked
That's one of the bad things about supply lines being on top
Post by: InBassAngler on February 03, 2013, 01:03:16 PM
There isn't any insulation underground.  The pipe comes right into the basement that is heated.  The only possibly spot the lines could be frozen are at the OWB.  The only valves on the system is a fill valve in the basement on the feed line, then there are some valves that are used to bypass the water heater or not.
I will say that who ever plumbed the system, I am not happy with.  I will be doing some re-plumbing this spring.
The only way it purges air is the over flow tube at the top of the tank that has dual purpose of overflow and make sure it doesn't build up too much pressure.
I really appreciate all the help.
Post by: InBassAngler on February 03, 2013, 01:06:01 PM
Scott, the supply is on the top.  I bet when it over heated and steamed out the pump sucked air, not water.  Will I need to replace that pump?
Post by: Scott7m on February 03, 2013, 01:08:25 PM
If it were plumbed properly that one open pipe on top the stove would be all that's needed
No insulation underground is scary lol..  That could make you burn over twice as much wood
Is your supply line coming off of the top?
If it is I'd pull that line off the pump, take a garden hose and try to force water through it back to the stove
You could probably hold enough pressure with your hand to make it work? Listen for air entering the stove
Post by: Scott7m on February 03, 2013, 01:09:05 PM
That little grundfos is tough, it may have survived, but your air locked!
Post by: baldwin racing on February 03, 2013, 01:12:12 PM
sounds like pump died they will hum and not be pumping......also check to make shure there is not scall or anything clogging it on the end of the pump.... I use the threaded valves that look like  (your out door hose valve). you can buy them threw lowes....they are brass i will see if i have any pics.....they have bleeders built right in and you can screw pex fittings in them on both ends.....at pump i just have the flare ends with ball valve in them....normally around $50 a set....
kelly
i run rv antifreeze in my system also when my out door died i run 3-4 full cases threw it and then unhooked it in middle of winter.....it worked and i still have rv antifreeze in my new indoor model....but when i filled the system i used water to delute it some....
Post by: Scott7m on February 03, 2013, 01:13:58 PM
I would guesss if the pump feels smooth and isn't rattling it is ok but you didn't do it any favors.
If the pump were on the bottom where it should be the weight of the water in the tank can also aid in pushing the air out..
Post by: InBassAngler on February 03, 2013, 02:26:07 PM
Yea the pump isn't rattling.  I plan on placing on the bottom for that fact of the weight of the water to help with pushing air out and not run out of water.
Post by: Scott7m on February 03, 2013, 02:45:39 PM
It has more benefits than that as well, also creates more balanced water temp from top to bottom which is also important.
Post by: willieG on February 03, 2013, 02:49:11 PM
with no insulation, if you werehaving teh cold weather we were here in ontario and you were moving no water for  even as little as 24 hours you could easily have frozen any lines above the frost ( your hint to this was when you said "i opened the drain in the basement and no water came out" I would be taking the lines off the pump at the OWB and seeing if i could run a nice stiff number 9 wire down there till you knew you were all clear on the ice factor? i just read you have no insulation so i hope your pipes are deep enough to be below the  frost line in your area? with no insualtion yoru water in the pipes would cool rather quickly when not moving.
i am with everyone else on here that you likely  have (had) an air lock but if you ahve not moved water in your pipes in 24 hours, and you have freezing temps you likely have some frozen lines (at least what is above ground?)
jsut some thing you might like to look at before starting the pump again?
