Outdoor Furnaces - Manufacturers WITH EPA-Certified Models => Central Boiler => Topic started by: newmanab on February 21, 2013, 05:36:36 PM
I bought a used CB-6048 a couple of years ago, and have been very happy with it. Today i was in an area for work that had a central dealer nearby. I was amazed at how small the fire box is on the 1450 and 2400 e-series. I load my classic every 12 hrs with only a 5-6 pieces of wood, do to it being over sized for my application, but couldn't pass up a good deal ::).
I was just curious if anyone has posted a youtube video of weekly cleaning in their e-classics? Looks like there is definitely a little more labor involved compared to what i currently do.
I would some day like to switch to a gasser but i am sure thats a few or many years away. Just searching for a little feed back.
Currently heating:
1000 sq pole barn with radiant heat.
3000 sq ft house forced air and dhw average insulation
Thanks!
Currently heating:
Thanks!
Hey newmanab
My house is similar in size to yours heating with forced air and heating domestic water I don't have the pole barn wish I did but I fill mine pretty good and Im getting 16- 18 hrs with the current 10 degree lows and 30 highs The heat exchanger tubes are a little different between the 2400 and the 1450 as far as the cleaning but if I do a good cleaning I can clean the tubes and the firebox in about a half hour and do a pretty good job in that time frame. Push the ashes to the front of the stove in the reaction chamber every other day takes about a minute I will clean that area when I do my weekly cleaning I do it every weekend but you could make it every two weeks if you had too. I don't think its bad except when the weather doesn't cooperate I have the 1450 by the way I will send you a video if I can this weekend
Jack
Hello Newman, I burned a Classic 5648 basically the same size as your Classic 6048 model for 7 years.
I now have their Eclassic 2400. (same size) Burning 30-40% less wood, which saves me a lot of back work.
I was pretty anal in my maintenance and cleaning of theClassic, as I am about my E2400.
I find the 2400 very easy to operate. It does prefer seasoned wood.
I may spend no more than an extra15 minutes total per week to keep it clean to where I want it.
The end of season clean-up and shut down is where I probably spend and extra hour of cleaning time.
Wood savings is well worth that little time.
Yes the firebox is a smaller, but since it burns less wood, I still get a 24 hour burn even during the coldest winter nights, just as I did in my Classic model.
Jack & b-man thanks for the replies, alittle reassurance always helps. Maybe by the time i get around to purchasing one, the technology will be so far ahead it will clean itself :P. thanks again and look forward to the video.
