All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: CountryBoyJohn on February 25, 2013, 02:38:27 PM
After searching around this site, consulting with my insurance agent, and exploring an installation manual, I have not been able to come up with any solid recommendations for good set-back distances for the OWB from a house. Insurance agent said what ever the manual says. Manual says keep 36" away from anything flammable. Nothing very specific on how far away from the house to locate the boiler.
It is shaping up for the best place to locate my boiler is directly behind my semi-detached garage. Close enough that my return/supply lines will go from the back of the boiler directly through the wall into my garage without having to be burried. I have a slab floor and coming up from the gound is not feasible. My plan is an insulated connection on the exterior of the wall via the method that has been shown on this site a couple times before in other threads.
Any thoughts?
There isn't a set answer I don't think. Most books will say 36" from a flammable surface or something like that, I would likely just set it out from your shop 6' or so to give plenty of room to access the back of the stove comfortably. I wouldn't be worried about it hurting anything, if I were that close though I'd def extend my chimney up some though
Ok. Here is what I'm looking at specifically. (see attached PDF)
my building inspecter said that it has to be 12' away from my house so i went 14' to keep him happy!
I've never seen a building inspector in my area but just go with whatever the manufacturer says is ok....
Make sure it's listed for insurance purposes
Not all insurance companies require listing!
That's true, but at the same time, if I were sitting it within 4 feet of a building, I'd hate to give a lawyer a toe hold
Let me make it clearer, I wouldn't worry if it was out in the yard, but sitting it so close if wanna make sure i was covered, in 99% of owb installs, a ul listing is worthless to me
My insurance company required 10' clearance from the house.
Since mine is an air furnace I wanted to stay as close as possible.
No UL listing since it was homemade.
10', just enough for my trailer to slide through. :thumbup:
My insurance was 25ft or pay more, gives smoke close to enough time to get up, have another piece of pipe to go on once i get it braced. If go close plan on adding some extra pipe to it.
State of MA has a setback not sure what it was because I had plenty I know it has to be 50ft from property lines and like150 ft from another house
When I was thinking of installing the OWB, I called my local zone enforcement officer and inquired regarding town local zoning law. He said they go by manu. recommendations. I called my CB dealer who said between 20 and 30 feet from the nearest structure which happened to be my house, so I set it back 25 feet. So, if ever you're in Enfield, NH...you now know the rest of the story. Roger
Insurance companies...The biggest scam they are..
