		All-Purpose OWF Discussions => Plumbing => Topic started by: Dirtslinger on August 18, 2013, 08:28:43 AM
				Where should my a coil be? Above the heat ex changer from outdoor boiler or below it?
 Depends on a whole slew of variables, there is no perfect way.  What are your concerns?
 Not really and concerns. I am just installing a new furnace and wanted to make sure it was done proper.
				Well sometimes we have to install them above the a coil, sometimes below.  It just depends on how your existing system is done and installed.
 It will all be new from the ac unit furnace
 heat runs all will be replaced
				Well in that case I'd install it in the main duct where it exits the plenum
 If its possible, need to know more about if its in a house or mobile home, is it a split system etc.  In a closet or all under the house.
 But if its under the house or in a basement what I said will work the best
