All-Purpose OWF Discussions => Plumbing => Topic started by: Farmer85 on September 19, 2013, 01:22:46 AM
Title: Auto fill good or bad
Post by: Farmer85 on September 19, 2013, 01:22:46 AM
Hi I Have an earth rancher 365 new to me. Wondering if anyone has ever added auto fill option to an owb? I guess figuring out how to install float would be hardest thing. I think it's a good idea mainly incase of a leak when not around I assume it would at the very least quench the tank and keep from overheating. Any ideas or does anybody even worry about it.
Title: Re: Auto fill good or bad
Post by: jerkash on September 19, 2013, 04:52:13 AM
If you stove is new, I wouldn't worry about it.  It should be many many years before it ever leaks and if it does, it will start off very small.
Post by: slimjim on September 19, 2013, 05:39:59 AM
I have done auto fill on some of my installations using the safegard low water cut off and electronic water feeder by using the alarm terminal on the low water cut off to power the feeder, works great for about 3 years and then the bulb on the sensor gets so nasty that it stops working, my opinion don't waste your money or time
Post by: Scott7m on September 19, 2013, 07:10:12 AM
Yep, I think there pretty goofy.  If companies have to have an auto fill float I think that's a sign there is some issues, which earth doesn't but a couple do.
With a conventional furnace like earth often times there isn't enough fuel in the firebox to completely boil it dry, at least I know that some companies kind of use that as a safe guard by saying well this firebox will hold x pounds of wood and it holds x number of gallons.  So if it overheats there is only enough energy available to boil out 75 gallons of water, or something of that nature
