All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: pointer80 on December 20, 2013, 12:30:23 PM
Hi everyone again, I am also curious about what kind of instillation everyone used when they installed there underground pex lines? I have mine installed in a insulated pvc pipe which is a smaller pvc pipe inside a larger pvc pipe with rigid foam insulation between the two pipes. I believe the brand is urecon. The pipes have a male and female joint and then a butylene "Band-Aid" on all the joints for water proofing. Thanks all.
I used something similar brand name is Insul-Seal. http://www.insulseal.com (http://www.insulseal.com)
