Outdoor Furnaces - Manufacturers with NON EPA-Certified Models Only => Shaver Furnace => Topic started by: hill dweller on February 09, 2014, 08:50:38 AM
Title: New to this
Post by: hill dweller on February 09, 2014, 08:50:38 AM
Got a 165 coal first week of november furnace has working very well did a couple mods i read on this site only big problem is door gasket, i want to replace with rope gasket and want to know what size gasket i should get.
Title: Re: New to this
Post by: hondaracer2oo4 on February 09, 2014, 08:55:33 AM
My buddy has the same one, we replaced his with 3/4 rope gasket but since there is really no channel for the gasket to sit in it doesn't work well. I would suggest getting some flat gasket and using that instead. Something like this https://woodheatstoves.com/glass-gasket-6-x-12-flat-tape-gasket-wadhesive-p-12257.html I would try a stove shop and see if they have any flat type gasket.
Post by: hill dweller on February 09, 2014, 06:08:48 PM
Thank you i have seen that others changed to a rope gasket and didn't know what size to get. I tried some mine run coal this year didn't work out so well going to try some nut coal and see how that works out.
Post by: doow14 on February 10, 2014, 05:45:50 AM
Hey Dweeller,does shaver make a 165 specific for burning coal?did it come with a shaker grate? how is it different from a regular 165.
Post by: jimr on February 10, 2014, 06:14:03 AM
I used a 1 in x 1/4 in flat rope gasket with good results
Post by: hondaracer2oo4 on February 10, 2014, 09:28:02 AM
No difference that I know of. My buddy has the 165 and ordered the "shaker grate" with it but it's really a joke. They just put another grate ontop of the regular grate and give you a long rod to pull the top grate with so that it allows the clinkers to fall down.
Post by: doow14 on February 10, 2014, 11:24:30 AM
my owners manual says you can burn wood or coal but burning coal voids the warranty.thats why I wondered if shaver made a stove specific for coal.
Post by: brian45786 on February 10, 2014, 06:26:27 PM
I have a shaver 290 and we have made several mods to the stove, reguarding the door gasket this is what we did, gound away the entire outside piece of 1/4 stock that was only tacked every 4 inches and replaced it with 1 inch strap and did a solid weld all the way around, we used 3/4 in rope gasket and installed it with permatex gold high heat adhesive, in order for the door to close and function correctly I had to redrill the bolt hole to square the door up to the stove(this was done prior to gasket mod) . it was also a little tight on the latch for a few days, but it seals super good, 100% better than using silicone that is squashed to nothing on some sides and very thick on the other.  :)
 you can view the pictures here : too bad: i took the link down, this site loaded my server full of viruses  >:(
Post by: hill dweller on February 10, 2014, 06:27:54 PM
Hondaracer is right the shaker grate is the only difference its just a regular wood burner with a shaker grate and they call it a coal/wood furnace so it can be sold in pa and other states.  my manual said nothing about coal voiding the warranty.
Post by: hill dweller on February 10, 2014, 06:30:39 PM
Thats the problem i'm having silicone squashes to nothing and leaks like a siv. thank you for the advice
