All-Purpose OWF Discussions => Plumbing => Topic started by: cdie on February 20, 2014, 01:16:18 PM
Title: install questions
Post by: cdie on February 20, 2014, 01:16:18 PM
Finances made me buy  used and found a glenwood 1250 boiler with +/- 50' of 1" Pipe snaking thru firebox and 9 gal tank on top of unit.  Installing in a shed 10' from the house. 20' of crawlspace and 15' more to the  oil boiler.  Unit has 2 3/4" inlets and a n 1 1/4" outlet.. existing boiler  is 1 pump with 2 zone valves. 1 is 15' from pump, other is35'.  What size line from boiler to boiler? Do i need to pump from b to b?  Thanks
Title: Re: install questions
Post by: LittleJohn on March 03, 2014, 10:34:02 AM
I would look at your BTU requirement and what 3/4", 1" and 1.25" are each capable of.  I personally would run as large of line as I could get and afford, and run that between the 2 boilers.
In regards to the statement about pump(s), not sure exactly how your system is setup, but you will need something to move the water  ;D
Post by: slimjim on March 03, 2014, 11:16:30 AM
Have you thought about proper, non powered dump zones and adding more expansion tank, if not you are begging for trouble!
Post by: userdk on July 09, 2014, 02:00:13 PM
Your local glenwood dealer would probably best be able and willing to help you.
Good Luck!!!
