All-Purpose OWF Discussions => General Outdoor Furnace Discussion => Topic started by: ijon on February 26, 2014, 08:21:26 AM
Title: Portage and Main
Post by: ijon on February 26, 2014, 08:21:26 AM
Does anyone know if the last turn of the scotch marine design on the portage and main boiler bl 28-40 would act as a smoker? Or would it be to hot? Does anyone  with this boiler know the stack temp?
Title: Re: Portage and Main
Post by: Scott7m on February 26, 2014, 08:31:28 AM
Depending on cleanliness you may see it as low as 260 is but more commonly a bit higher and if dirty up to the 400's
Post by: CountryBoyJohn on February 26, 2014, 09:05:42 AM
You may try a search on "smoker" or something like that.  There was a thread several months ago that several guys said they've smoked some meat in their by-pass areas on their stoves.
Post by: Crow on February 26, 2014, 11:54:59 AM
 ijon, I checked my temps in the last couple weeks at the back of the last pass before it enters the chimney and I was getting 160 degrees at idle and 520 degrees by the time it shut off.
Post by: ijon on February 26, 2014, 02:36:56 PM
Thanks to all.
Post by: MattyNH on February 26, 2014, 04:47:23 PM
This is a question for slimjim
Post by: slimjim on February 26, 2014, 05:46:38 PM
That sounds about right, haven't run one enough to know for sure though.
Post by: mlappin on February 26, 2014, 09:08:27 PM
I see an option available in the future, "heat your house while smoking your meat"
Post by: Sloppy_Snood on February 27, 2014, 08:37:42 AM
You don't do these things in Indiana because bad people throw animal remains, manure, paint, tires, asphalt, and coal in our OWBs....
....makes the meat too crunchy.  :P
Post by: ijon on February 27, 2014, 10:40:09 AM
     Good one.
